| Chip Amps Amplifiers based on integrated circuits |
#121 |
Wester,
your 1.2C/W for each 3886 chip is on the nail for 70Vcc, 8ohm speaker and Ta25degC. National say 2.4C/W, you have chosen exactly double. I will be using 78Vcc, 8ohm speaker and Ta=35degC (sink inside the chassis) I will need 1C/W for 1off 3886 or 0.5C/W for two 3886. |
#122 | |
I would thank any help about that matter.Sabre, those heatsinks are definitly too small. Also your speaker output wires seem too thin, hook up there something of higher gauge. I would also place the obligattos between the connectors and the heatsinks. I have made a plan for testing the tantalum resistors and the LM318 in both packages. First, I will populate both boards with the PRP resistors, but one with the metal can encapsulation and one with a DIP-8 ic. I will let it burn-in for some days, like 100 or 150 hours, to not address false results due to not burned-in components. After a detailed extensive listening session (to be able to memorize it's sounding characteristics), I will try to find any difference between both boards. Listening one board at a time, of course. Though, I am not expecting any discernable audibly difference between both IC's. Then, I will put the same IC in both boards, and listen to it again. After having memorized it sound, I will quickly change the PRP resistors for the tantalum ones, and I will listen for further changes. I will expose all the differences my humble ears are able to discern. My heatsinks are really killer ones at 30x12x5cm (12x5x2 inches) size, one of them for each board.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#123 | |
Reality first!
Dario ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition GB Second Run |
#124 |
I don't have data for your build nor your ambient conditions, but if I were allowed to guess then 300 by 59 by 50mm (sawn to half height) would probably do for a pair of 3886, not just one.
#125 |
I bet one heatsink should be able to handle even 4 LM3886. I wasn't intended to buy this one so big, but the enclosure I liked had that big heatsinks. Is this one:
modushop.biz And I am going to put inside a Myref_C and an standar gainclone I have without enclosure, from chipamp.com.
#126 | |
Shop Steelworks Aluminum Flat 1/16" x 1-1/2" x 6' at Lowes.com' Just cut a length of that and mount it between the chips and the chassis with thermal paste. This bar will spread the heat to a larger area of the thin chassis and the chassis will dissipate the heat. The chassis wall is too thin to spread the heat quickly enough but a 1.5 wide x 8 long x 1/8 inch thick piece of metal will spread the heat to a larger area on the chassis. Remember the thermal paste and insulation!! As for the 318, if the amps work with a good 318, then it has to be a pin compatibility issue or a voltage supply issue. Easiest first step is to measure the voltages to the 318.
Troy Thinking positive doesn't make things better, it makes you a better person. |
#127 |
Hi guys,
I have a few more dumb questions as I continue to stuff my boards. - Does the 220 uF Blackgate go to C9, it's unclear from the boom ? - I recieved 4 tiny little ceramic caps with my kits and I'm having trouble figuring out where two of them go. One came attached to a peice of cardboard and is labeled uc221, the other is loose with shorter legs and is labeled 100 on one side and K2J on the other. - As added info could anyone tell me where the other two go, I installed them in C12 and C21, but would like to make sure before I'm done and fire them up. - I'm assuming that you just leave the spots for the caps that aren't being used blank without jumpers (C17-20), am i correct ? Many thanks, PJN |
#128 |
Reality first!
The Black Gate goes in C9.
The ceramics are C10 (22pF), C12 (220pF) and C34 (10pF), if you have only two values something could be wrong... and for sure none of them goes to C21... Regarding C17, C18, C19, C20 positions simply leave them empty, no jumpers!!!
#129 |
#130 |
Thanks Dario, I'll double check everything when I get home tonight.
PJN |
| New guide from TI | FastEddy | Parts | 0 | 19th August 2007 08:36 PM |
| Various questions from a diy noob regarding the myrefC. | thegeek | Chip Amps | 8 | 7th June 2007 04:49 PM |
| Everything required to assemble MyRefC and Kookabura. | Tony D. | Swap Meet | 3 | 18th January 2006 02:54 AM |
| what is a wave guide? | Joules | Multi-Way | 7 | 12th May 2005 02:25 PM |
