Old 9th June 2010, 03:14 PM   #101
Originally Posted by troystg View Post
It has been established that having the LM318 nested in the feedback loop causes the LM3886 to run warmer.
I don't recall that. Would it be easy to find the discussion?
Old 9th June 2010, 03:29 PM   #102
troystg is offline troystg  United States
troystg's Avatar
Easy? Most likely not.
Possible? Certainly.
Will I try to reinvent the wheel? No.
You are welcome to read every post in the multiple threads. I have read somewhere about the 95 percentile of them over several years time.
Has heatsinking and larger than normal heat sinks been brought up in those past posts? Yes.
Where? Good luck finding. This is an OLD subject / topic with LOTS of information to sort through.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 9th June 2010, 03:30 PM   #103
PJN is offline PJN  United States
Hi Guys,
First let me say thanks to Uriah for taking the time to make this group buy a reality.
I've begun stuffing my boards and have a few questions.
- Are the 1K Dale resistors supplied for R1 and R4 really rated for 1W, they seem small ?
- The BOM call out for Q2/Q3 to be BC546A, but BC546B supplied. Probabily ok but wanted to make sure.
- R11 spec'd as 1R, reading ~ 1.3 - 1.4 R with my meter. I'm assuming it is simply meter error with my cheapy meter.
- The BOM calls for two 75 K resistors For R15 & R16, but I got three in my kit. Is the third 75K just a unintended bonus part ?
Thanks,
PJN
Old 9th June 2010, 03:31 PM   #104
udailey is offline udailey  United States
Passive Aggressive
A sink that size is pretty small. It also depends on what you mean by 'pretty hot'. If you put it in a closed box with no way to vent I wouldnt expect it to last long. I usually use a P4 sink around 3x3x2. About double what you are using. More than enough for the load they have to drive in my house. 96db speakers make it easy on any amp. If you are running 87db and play it loud you will need larger and larger sinks. With my speakers the P4 sinks rarely got warm. I mean you could hardly tell the difference between them and air temperature.
URiah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 9th June 2010, 03:41 PM   #105
Passive Aggressive
Originally Posted by PJN View Post
Hi Guys,
Thanks,
PJN
I think those 1k's were actually 2W so you are safe. They LOOOK small but have you seen Panasonic 1/4W
Yep, BC546B is fine.
Its your meter.
Its a bonus part.
Let us know how it sounds Cant wait to start hearing some impressions.
Uriah
Old 9th June 2010, 04:26 PM   #106
I have an original RevC from Twisted Pear that I built several years ago to compare it to, so it should be interesting.
Old 9th June 2010, 06:41 PM   #107
troystg's Avatar
I would definitely like to hear (pun intended) your opinions.
I think this circuit is fully capable of resolving the differences in components.
I have purchased six channels (2 from twisted pair, 4 from Uriah's 1st GB), built four, , so I couldn't justify another two....
Troy
Old 9th June 2010, 08:19 PM   #108
regiregi22's Avatar
Got my package! Thank you one more time, Uriah. Having a fast look at the contents arise me some questions, which I will ask later, when I get time to look at it closely.
BTW, you made a great effort in packaging it, tons of nearly individual bags and very compact all of it. Pictures promised.
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 9th June 2010, 08:38 PM   #109
Passive Aggressive
Youre welcome Regi. Note that you have the tantalum and metal hat in there for experimenting.
Uriah
Old 9th June 2010, 09:11 PM   #110
Bill_P is offline Bill_P  United States
Just a few words about the power ratings resistor manufacturers publish:
There is no free lunch - the temperature rise at a given power will be greater the smaller the resistor. The small resistors are constructed of materials that can withstand very high temperatures, up to 230C in the case of the CPF2 resistor. For printed circuit board mounting you can't run anywhere near the rated power and maintain sane temperatures.
The highest DC voltage for the amplifier should be under +/-35 volts so the resistor will dissipate at most 1/2 Watt. That should produce a temperature rise of 40C according to the datasheet. At a normal room temperature and with allowance for a slightly higher internal enclosure ambient temperature, this produces a reasonable operating temperature. But there is no way you could realistically run 2 Watts dissipation with these resistors. In fact they aren't good for much more than 1/2 Watt the way we are using them.
New guide from TI FastEddy Parts 0 19th August 2007 08:36 PM
Various questions from a diy noob regarding the myrefC. thegeek Chip Amps 8 7th June 2007 04:49 PM
Everything required to assemble MyRefC and Kookabura. Tony D. Swap Meet 3 18th January 2006 02:54 AM
what is a wave guide? Joules Multi-Way 7 12th May 2005 02:25 PM
Copyright ©1999-2013 diyAudio
