MyRefC build guide - Page 106 - diyAudio
Old 9th February 2013, 04:13 PM   #1051
Send a message via Yahoo to ThuyTN
Thanks. Looking forward to comments about this specific value.
Old 9th February 2013, 04:28 PM   #1052
Send a message via Yahoo to linuxguru
Originally Posted by bcmbob View Post
It is your call, but linuxguru can send you a completed unit. That's what I bought. I'll just say it was a most significant upgrade to the MyRef series prior to Dario's Fremen Edition.
Bob - thanks for the plug. I now also have a fully-discrete LF05 prototype which also works instead of the LM318. I'll send out a pair with your LF03s, which you are welcome to evaluate at your convenience.
The TL071 will work in place of an LM318, with similar stability but worse sonics. The OPA627 and LME49710 are both marginally unstable in a Rev C - compensation changes will be required, and at the minimum C10 may have to be removed.
Old 9th February 2013, 04:36 PM   #1053
Any info regarding the LF05? Is it a direct replacement for the LM318?
Old 9th February 2013, 04:48 PM   #1054
Yup, the LF05 is a direct drop-in replacement for the LM318, and the first pair of prototypes work without modification in a Rev E. I will get a few prototypes into local DIYers' hands to ensure that there is no regression before making it generally available - give it 4-8 weeks.
Preliminary audible sonics of the LF05 are comparable to the LF01.
Old 9th February 2013, 05:09 PM   #1055
Great to hear that, put me on a list for a pair then.
BTW, would this work with the Rev C v1.2 too?
Old 9th February 2013, 06:14 PM   #1056
Reality first!
ClaveFremen's Avatar
Originally Posted by lil' knight View Post
I've just skimmed the BOMs... What's the correct value for R2? I see 2 different values, 33k and 10k, from 2 different BOMs. Not sure which is the one to go with. I'm using the v1.2 PCB.
Both are correct.
The 33k value comes from LM3886 datasheet and Penasa's original BOM.
TP boards (including v1.2) also spefify the 10K value.
All my BOMs speficy 10K
Such value comes from a Nelson Pass post.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
Old 9th February 2013, 06:33 PM   #1057
Thanks for the clarification
Would there be any negative effect if I use larger value for C13, say 6.8uf? I have a lot of 6.8uf Solen caps left from other projects.
Old 9th February 2013, 06:37 PM   #1058
Reality first!
According Penasa the amp work as he intended with values around 1uF, TP boards specify no more than 2.2uF but I suppose it will work with higher values also.
But I suggest you to stay in the 1uF-1.5uF range
Dario
Old 11th February 2013, 04:01 PM   #1059
Thanks, Dario. I'll stick with the 1uf cap then.
Looks like the Omron relay is out of stock now. Would this one work just fine? 833H-1C-C-24VDC Song Chuan | Mouser
Old 11th February 2013, 06:00 PM   #1060
Reality first!
It should but never tried it... or you can buy the non sealed Omron: 653-G5LE-1-DC24
Dario
New guide from TI FastEddy Parts 0 19th August 2007 09:36 PM
Various questions from a diy noob regarding the myrefC. thegeek Chip Amps 8 7th June 2007 05:49 PM
Everything required to assemble MyRefC and Kookabura. Tony D. Swap Meet 3 18th January 2006 03:54 AM
what is a wave guide? Joules Multi-Way 7 12th May 2005 03:25 PM
Copyright 1999-2017 diyAudio
