Old 25th May 2010, 02:46 PM   #1
Bedi is offline Bedi  Croatia
Default finally finished GC LM3886
This is my final version Amplifier GC LM3886.Power supply is separate from the amplifier, and the amplifier box containing the speaker protection, remote volume control and input selector.
Old 25th May 2010, 03:08 PM   #2
How does it sound? I used the same conenctions for my mono blocks and the cables are a nightmare for producing inteference, I have to play around with the position a lot to reduce the hum. Going to get rid of them altogether over the summer and hopefuly will sort it.
Enclosure looks great!
Old 25th May 2010, 06:30 PM   #3
It sound pretty good, but the hum is present when the maximum volume without attached inputs.I must say that I have not watched much of the position of cable and is perhaps the reason but the remote volume control can also cause the same problem.Thanks!
Old 27th May 2010, 12:18 PM   #4
maximum volume control AND inputs disconnected is not a normal operating condition. If it does not blow itself up nor damage the speaker then ignore this.
regards Andrew T.
Old 27th May 2010, 08:09 PM   #5
Thanks,AnrewT
Old 30th May 2010, 10:28 AM   #6
Razor_x is offline Razor_x  Croatia
Send a message via MSN to Razor_x
It looks beautiful
Do you have any schematic of remote volume control circuit? That is what I am working on so any help would be nice. I presume you used microcontroler and digital potentiometer?
Oh, now I see we are both from Croatia, are you active on Croatian forum elektronika.ba?
Old 4th June 2010, 09:38 AM   #7
cwteoh is offline cwteoh  Malaysia
some body told me... if you redure the cable length between PSU and the main board... you got better sound...
C.W. Teoh
Old 4th June 2010, 09:48 AM   #8
if you reduce the loop area and the inductance between the transformer and the rectifier, the PSU will perform better.
If you reduce the loop area and the inductance between the rectifier and the smoothing capacitors, the PSU will perform better.
If you reduce the loop area and the inductance between the smoothing capacitors and the amplifier then the amplifier can benefit from the improved performance of the PSU.
If you can reduce the parasitic effects of PCB and layout in any of these PSU and Amplifier assemblies then overall performance is likely to be improved.
The length of the cables has a significant effect but that can be quite minor in comparison to all the parts that could be wrong in the layout.
regards Andrew T.
Old 4th June 2010, 10:43 AM   #9
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
You'll do even better still if you run multiple grounds between the PSU and main board. In particular, a separate ground for the input RCA, another for decoupling returns, yet another for speaker return (assuming not a bridged design) and finally another one for signal ground (the feedback network ground return). If you do this, the cable lengths won't matter so much and the sound stage will in general get deeper, highs will be considerably sweeter. At least that's my experience from playing with amp grounding.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 8th June 2010, 12:51 AM   #10
I really like your design... I just got no idea how I want to get it started.
C.W. Teoh
FINALLY; I have finished my stereo LM3886 board. Dxvideo Chip Amps 25 24th May 2011 05:33 PM
166es-r finally finished and some ? kazoo Full Range 9 21st January 2011 12:23 PM
Yet Another Finished BrianGT GC...Finally!!! kec Chip Amps 15 1st November 2004 05:37 PM
I have finally finished my SUB! Fabiano Subwoofers 12 20th October 2003 12:39 AM
My dipoles are finally finished. sfdoddsy Multi-Way 35 22nd July 2003 02:05 PM
Page generated in 0.09446 seconds (79.78% PHP - 20.22% MySQL) with 11 queries
