is it right value
is it right value
Old 20th May 2010, 07:31 PM   #1
JO12 is offline JO12  Dubai
Default is it right value
hiii ....
I have question about value of capacitor
is a 0.027uf ciramic capacitor and value = 27000p (273)p
is it right??
and what about another capacitor
0.082uf is it (82000) p 823 p
and
0.001uf 102p
and
0.0027uf
0.001uf
etc..
Old 20th May 2010, 08:02 PM   #2
bob91343 is offline bob91343  United States
The first one, .027 microfarads is indeed 27000 pF.
The .082 is 82000 pF.
The .001 is 1000 pF.
To convert microfarads to picofarads you use a factor of 1 million, or 10 to the sixth power. These days, many use nanofarads, which uses a factor of 1000. So a .01 microfarad capacitor is 10 nanofarads, or 10000 picofarads. Just move the decimal point the required number of places, using zeros to fill gaps (or removing leading zeros) where appropriate.
Old 20th May 2010, 08:44 PM   #3
40 watt is offline 40 watt  Canada
here is a handy conversion table
Old 21st May 2010, 06:04 AM   #4
tangmonster is offline tangmonster  South Africa
tangmonster's Avatar
As a side note.
If you are going to use that circuit with an AC adaptor i would use a 12V adaptor and use another 7809 to the the 9V which should be much cleaner.
IF you are going to use it with a 9 or 12V battery permanently that configuration is just fine.
Old 21st May 2010, 04:27 PM   #5
I bought ceramic capacitor
for 0.027uf written on capacitor (( 2E273K ))
and another one for 0.082 (( 2G823K ))
is it right
and what dose 2E***K mean
ceramic capacitor
like this
green one
Old 25th May 2010, 10:40 AM   #6
193x197 pixels does not show sufficient detail.
A close up of both sides of each type would be much more informative.
regards Andrew T.
Old 25th May 2010, 11:22 AM   #7
infinia is offline infinia  United States
infinia's Avatar
green ones are asian Mylar film >Not Ceramic
1H = 50V
2A = 100V
2D = 200V
2E = 250V
2G = 400V
2J = 630V
Tolerance Code:
K = 10%
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 25th May 2010, 11:42 AM   #8
Prophetmaster is offline Prophetmaster  Russian Federation
Prophetmaster's Avatar
This capacitors is not ceramic All capacitors on a photo with a film insulator.
2E - may be type of insulator, K - capacitor may work up to 63 V
100pF=0.1nF=0.0001F 101
1000pF=1nF=0.001F 102
10000pF=10nF=0.01F 103
100000pF=100nF=0.1F 104
1000nF=1F 105
Adcom GDV-870, Pioneer PL-1250, Speakers Y-1, Prophetmaster's Amplifiers
http://nick-name.ru/nickname/id1103235/
Old 25th May 2010, 11:51 AM   #9
"2E = 250V"
This are low-voltage capacitors on a photo! 250V - capacitors will fail!
Old 25th May 2010, 12:07 PM   #10
kroto is offline kroto  Indonesia
kroto's Avatar
Send a message via Yahoo to kroto
I've been seen an article on wikipedia about capacitor coding (also with color code).
go search there, it may help you much.
If I wasn't wrong, 2E for 250Vdc and
K for tol'+/-10%.
is it right valueHide this!Advertise here!
Copyright ©1999-2017 diyAudio
