I'm running a set of low impedance speakers with my LM3886 chipamp power supply has a 20vac dual secondary transformer.
The amp doesn't break a sweat even with the speakers dipping to impedance lows of 3 ohms. I must say I was rather concerned that the chipamp wouldn't cope but it has done so with ease.
Below is the impedance plot of the speakers, the crossover has evolved somewhat since the first measurements which showed dips on both sides of the impedance peak to 2.7 ohms, now roughly 3 ohms.
Tony.
Tony.
I am not too good at DIY projects with complexity such as amps. Is there anybody who makes fully assembled gainclone amps for sale as a hobby? Tim Rawson used to do that on Audiogon but it seems he no longer is active. I also have TEAC AL700P amp that I want to get modded but can't seem to find anybody who does the mods anymore.
Hi Winter.
One of the worst loads your speaker provides is at 200Hz, ~3.2ohms and ~16degrees of phase.
Very gentle load.
Thanks Andrew, good to know! I'd never considered the phase, only the impedance (thinking low was bad) Obviously a lot more to it than I thought!!
Tony.
- Chip Amps
- LM3886 & low impeadence loads
