Old 18th May 2010, 02:40 PM   #1
Default In memoriam LM1875T -- we had so lttle time
I built me two LM1875 amps which have been going fine for a couple of weeks.
Today I built a third. Hooked him up to my junk-grade test speaker, switched on. Works, sounds fine, no problem.
So I hook him up to the woofer on a three-way speaker I made, with the other two amps on the other two speakers. Crossover is being provided by my PC. All three amps on the same PSU.
Sounds cool, everything's fine for an hour or so.
Suddenly -- the woofer jumps forwards and is straining to pop out the cabinet! That'll be DC on the woofer, no?
Naturally I switched off straight away. A visual check of the amp showed no signs of any shorted wires, no visible problem. The other two amps are fine.
What could cause this to occur? The only component difference in the latest amp is the electrolytics on the power pins. Could bad caps have murdered my amp like this?
Old 18th May 2010, 02:50 PM   #2
My sincere condolence...
Can you provide a schematic of your amplifier?
1: Do you have an output zobel?
2: Do you use a output inductor/resistor in series?
Did you check the temperature from the chip time to time? And how hot was it?
Do you have a oscilloscope?
Big chance the cause of this sudden suicide is oscillation caused by the capacitive or inductive load from the cables in combination with the voice coil.
With kind regards,
Bas
Old 18th May 2010, 03:16 PM   #3
Tubbe is offline Tubbe  Sweden
Probably oscillation as Sebastiaan has pointed out.
We will have to wait for the autopsy .
Tubbe.
Old 18th May 2010, 03:18 PM   #4
Thank you -snif!- it's a difficult time...
Pretty much like the standard application in the datasheet.
2M2 across the input, 2u2 input coupling cap, 22k input resistor, 22k feedback resistor, 1k gain-setting resistor, 100uF electro decoupling the feedback network from ground.
100uF electro plus 100nF film cap on the supply pins.
Supply is ±27.5 volts off-load.
Yup, 1ohm 220nF in series, as per the datasheet
No.
Chip was not very hot at all. Lukewarm, really. I didn't get crank it up, partly 'cos the power transformer is a bit small for three LM1875 at once.
I don't have a scope.
Now I wish I'd put the output RL on there. Would that kinda thing normally defeat the inbuilt protection?
Old 18th May 2010, 03:19 PM   #5
Have checked the input cap, and that's not shorted.
Old 18th May 2010, 03:27 PM   #6
Good news is the woofer's not dead.
Old 18th May 2010, 03:39 PM   #7
Bad news is if the amp was salvageable before, it ain't now.
Decided to check what the output looked like without the speaker connected.
Instantly on switch-on there was the smelly smoke. Also a little bit of dark-coloured gunk on the +ve supply pin, right next to the package. Not quite sure where that got spat from, but wasn't there before.
I kinda figured if the original problem was oscillation, the amp would be okay off-load. Did I figure wrong?
Old 18th May 2010, 03:57 PM   #8
Not that I want to argue with the masters from National semiconductors, but 1Ohm is a rather low value. What is the electrical serial resistance of your woofer voice coil? One of the benefit's of going active like you do, is that you can optimize the Zobel network for each driver.
So if u have the T/S parameters from each driver you can give a optimised Zobel for each driver.
The Zobel (Rz) resistor should be equal to the serial resistance of the voice-coil. Revc)
RZ = Revc
The (Cz) capacitor you can calculate by:
CZ = Levc / Revc2
Currently with only 1Ohm resistor the Zobel you have now has hardly any effect.
Second I think you need to isolate the amplifier with in series 10 ohm, and a inductor of around 12 turns (or around 0.7uH).
Next time, check the chips for heating up carefully, if so there is something wrong. Better is to use a scope and monitor the output.
With kind regards,
Bas
Old 18th May 2010, 04:01 PM   #9
you mean after you replace the dead chip you power it on again? But did you check the other parts for damage? If not, big chance if the original problem was oscillation, the 220nF capacitor and/or the 1Ohm resistor are damaged, and provide now a short-cut to the output.
With kind regards,
Bas
Old 18th May 2010, 04:03 PM   #10
infinia is offline infinia  United States
infinia's Avatar
Sorry about your loss
One simple thing to check that can fail sometimes, is the insulation from chip to heatsink. You can leave HS floating like I do, or grounded with insulator and grease.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Major hum and noise problems with my LM1875T amp fjhuerta Chip Amps 13 30th January 2010 06:04 PM
Problem with LM1875T amp - distortion, low volume and instability fjhuerta Chip Amps 12 26th January 2010 07:59 PM
Great AMP PCB for sale~LM1875T & LM3886 slowgay Swap Meet 2 16th February 2009 12:24 PM
in memoriam Fred N. AKA 807 Zen Mod Tubes / Valves 5 27th September 2005 01:41 AM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
Page generated in 0.13006 seconds (83.55% PHP - 16.45% MySQL) with 11 queries
