Old 14th May 2010, 09:33 PM   #1
vzon is offline vzon  United States
Default Headphones with a TA2020
I was wondering what happens if you hook a pair of headphones to a TA2020 amp such as the Lepai.
Does the amp blow if you connect the grounds from the left and right channels together? Most headphones have the 3 wire plugs with a common ground.
Is there a work around if the grounds can not be hooked tegether? Other than re-wiring the cables on the headphones?
Old 15th May 2010, 03:32 AM   #2
jcx is offline jcx  United States
yes you expect the bridged outputs to "fight" each other either current limiiting or blowing up
a way around this would be audio frequency output transformers to turn the bridged drive into (TRS)gnd referenced single ended - a little backwards from usual practice
of course you can get 2 orders of magnitude lower distortion with analog "chip amps" like the TPA6120 into even pretty inefficient headphones - with higher average efficiency too since you'd have much lower quiescient current running the many fewer transistors of the op amp - and no high frequency switching noise to filter out
Lepai TA2020 westsounds Class D 5 3rd January 2010 08:03 PM
Tripath TA2020 e_fortier Class D 6 4th March 2009 04:43 AM
Ta2020 Bengali Class D 0 29th September 2007 05:28 AM
Eb-ta2020 opentop Class D 16 30th May 2005 07:42 AM
Page generated in 0.14550 seconds (-19.23% PHP - 119.23% MySQL) with 10 queries
