| Chip Amps Amplifiers based on integrated circuits |
What type of volume pot do I need for chipamp.com,
50K, 100K, 25K? audio log? How dose the K affect the choice? What is the difference, many posts many different answers. |
#2 |
if your source can drive 10k load properly, then go for 10k log law dual pot. Audio and log law are similar/same.
regards Andrew T. |
#3 |
Is this built and tested?
Make sure you use all the parts. The ones shown as "optional" are not, only unless you have a real good reason otherwise.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#4 | |
I use my tv for control now, and want to add a vol control now been working on the tv for 3 years. Please explain what the different K's do to the amp. |
#5 |
If the LM3886 chipamp had a Dual Audio Taper Stereo Potentiometer, what Z would it be?
20K, 25K? This question has nothing to do with the source just the chipamp. Thank you |
#6 | |
For example, you could use 1M pot, but you must shield the input leads carefully or you can get hum from nearby electrical devices. If I was going to use the amp solely with my headphone music player, I would select a pot of low resistance because of the low impedance of the player's headphone output amp and the power amp would be pretty immune to electrical noise. You see, it doesn't matter what chip amp I use, it is the source which determined the volume pot. I should point out that if a particular chip amp has a lower input impedance might preclude me from using a higher value pot because the signal could be reduced too much. |
#7 |
Since the amp has 22K input impedance, I usually use 25K pots, log of course.
10K will work fine too, but may be too low with some sources.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#8 | |
Can you recommend a few pots and a few rotary non shorting selector switches so I can add two or three RCA inputs? I appreciate the other answers but the "sources" will vary from my sons protools Mbox to his Hauppauge TV card, or PC sound card. knowing the sources will change, is the 25K pot the best choice? I was told by Parts Express that the pot was to match the amp, perhaps a detailed explanation in the forum would help. |
#9 |
The input resistance is not an isolated parameter. It is not determined by 'lower is better as long as your source can drive it'. As little as most sources have any problems to drive 10k or even lower impedances.
One of the goals is that both input pins see the same impedance for best CMRR and to cancel the input offset voltage as good as possible. A DC-coupled pot wiper is not a constant impedance so obviously not the best choice whatever its nominal value. You need to AC-couple the wiper or use a buffer stage in between for best results. Another goal is that the filters between source and amp work best. With most sources being AC-coupled you would either want the highest possible impedance to bring the resulting high pass roll-off as far down as possible or the best matched impedance to form the optimal addition of the high-pass filters at the inverting and non-inverting inputs for your combination of amp and speaker. The latter is usually not possible, if you use varying sources, so you need to find a value that works with a range of sources. Usual input impedances of 10..100k on commercial amps hint at the direction to go.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#10 |
John, Peter, Pacific and I all agree. Don't use a high value pot.
regards Andrew T. |
| volume pot | william1981 | Solid State | 5 | 25th February 2007 10:31 PM |
| Volume control : - pot' or pot' variable feedback resistor (gain) ? | ash_dac | Solid State | 5 | 1st August 2006 05:07 AM |
| Volume pot question | gjo | Tubes / Valves | 9 | 18th March 2004 02:07 PM |
| Gain pot instead of volume pot | boyofwax | Solid State | 5 | 14th February 2004 02:37 AM |
| New Volume Pot | lilolee | Parts | 7 | 3rd August 2001 11:43 PM |
| Page generated in 0.11560 seconds (78.47% PHP - 21.53% MySQL) with 11 queries |
