How do I wire up this transformer for 110V mains?
Old 10th May 2010, 11:11 PM   #1
454Casull is offline 454Casull  Canada
Default How do I wire up this transformer for 110V mains?
http://www.apexjr.com/images/66938_sc7.pdf
What are the third wires for on the primaries?
Old 10th May 2010, 11:43 PM   #2
infinia is offline infinia  United States
infinia's Avatar
I think they are just extra connectors (leave them open by insulating them) they are the same color code.
parallel 120V PRI windings ( dots to dots) or BLK to BRN and WHT to BLU etc
If your 110 is really 120 > No load voltages s/b close to 43 VDC
Boderline HV >>> PS let use know if your chip amp does OK with your mains measured.
Old 11th May 2010, 11:00 AM   #3
R.I.P.
use a mains light bulb tester to power up each time you change or add something to a mains powered project.
A wrong wiring of the two primaries can quickly burn out a perfectly good transformer if the fuse does not blow quickly enough.
regards Andrew T.
Old 11th May 2010, 02:58 PM   #4
nm]
How do I wire up this transformer for 110V mains?Hide this!Advertise here!
How to wire this trafo for 110V? maurycy Chip Amps 4 30th March 2010 05:31 AM
Using 220v transformer with 110v mains DarpMalone Power Supplies 7 10th March 2010 08:12 PM
Isolation transformer. North America 110V argonrepublic Equipment & Tools 6 30th November 2009 12:43 AM
Aleph 3 with 110v->220v transformer roee Pass Labs 5 4th May 2004 08:59 PM
