| Chip Amps Amplifiers based on integrated circuits |
Hello! I came here with big intentions but after some reading became smarter.
I'm planning to build 2 channel LM3875 gainclone amplifer for diy speakers (theyr not built). it is useful to know that i've completed opamp project in past (cmoy). My questions are pretty basic. Can i use just mp3 player, cd player, phone mp3 for imput or i need preamplification? Is it strongly recommended to use quality components like quality resistors, caps and what about grounding off transformer? How much will affect speakers sound quality and as theyr not built yet then witch ones is to build for best result? (i'm planning to build with 2 drivers) What about speaker, amplifier power levels. Thank you for reading and i would be more than happy to read your post! |
#2 |
find out from the specification or the retailer what the outputs are in each of your sources.
We cannot do that for you. Alternatively, measure the source voltage and source impedance. We can help guide you through that.
regards Andrew T. |
#3 |
Good quality commercial grade parts are fine, don't go mad on exotic stuff.
Power output isn't hugely important... to understand why you need to appreciate that to get a 3db increase in sound level requires a doubling of power, and that in itself gives a barely noticeable increase in "sound". Of far more importance is the efficiency of the speaker, a large floorstander @ say 93db watt will be far louder with a 10 watt amp than an 82db watt speaker with a 200 watter (I have just picked those figures out of the air before anyone does the maths ) Grounding is of the utmost importance... and it's where 99% of DIY builds fail... and it's to vast a subject to sum up in a few lines here
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#4 |
93dB speakers and LM3875 will be really loud. The amp can use the signal directly out of the source, but with an active preamplifier it's better. Even a buffer does a great job.
Any solution is a compromise. |
#5 | |
50W adds about 17dBW to the basic 93dB/W @ 1m This will result in ~105dB @ 2.5m listening distance from a pair of 50W amplifiers driving a pair of these 93dB speakers. 105dB is not really loud for transient peaks. "an active pre-amp is better" How? better sound/better voltage/better distortion/better bass/better spoken voice/better what. "even a buffer does a great job" How? define a great job.
regards Andrew T. |
#6 |
Maybe for you 105dB isn't too loud, but for me it is. The usual listening level is around 80-84dB.
OK, I must admit that I was too short in explanations. An active preamplifier before the 3875 will adapt the impedance between signal source and 3875's input impedance. If the latter runs in inverted mode, the input impedance will be pretty low. One possibility would be to increase both feedback resistors, but this will mean higher noise (the higher the resistor value, the higher its noise will be). If needed, the preamplifier can also have tone control, a voltage gain, balance, RIAA correction etc. If the signal source has a high output impedance, the sound will be pretty "blurred", loosing the transparency, along with a voltage decrease. A voltage buffer i.e. voltage repeater has a voltage gain 1 (well... around 1) and it has the only purpose to adapt the impedances of signal source output and amplifier input. A standard CD/DVD player pretty much doesn't need either of those, since their output is fine, usually 1kOhm/2Vrms. With a tape deck or a turntable the situation is way different; even though it will work, the levels will be unsatisfying and it will sound like crap.
#7 | |
Average listening level is usually around 20dB below peak level. 80 to 84dB at 2.5m from a pair of speakers is about 10dB above conversation level. I would call that comfortable. 95dB is loud by my definition. and 20dB above that is 115dB. about 10dB more than 50W into 93dB/W can achieve.
regards Andrew T. |
#8 |
fistly in conclusion "you" recommend building preamp. I quote "The amp can use the signal directly out of the source, but with an active preamplifier it's better. Even a buffer does a great job."
Is it needed? i've build my cmoy and in result i got small buzz and different gains due stereo pote. (my cmoy was in hammond case, witch was fully grounded to bat minus. secondly its art to build good grounding. can you give me some tips. Nice discussion but sorry. i'm feeling bad for not getting all what your saying. So preamp it is! what chipto use and what about psu. maybe you add link to project that will suite my needs. can use with mp3 player if wanted. psu and amp in one case. maybe someone have good 2 driver speaker project, refer link. all i want is to get into diy audio. wost that can happen to me is building 150$ amp what will not satisfie me. Last edited by ic4ru5; 11th May 2010 at 03:03 PM. |
#9 | |
It's not an easy concept to grasp I admit, read up on it all, look at recommended wiring layouts and try and see what is being achieved. It took me years to fully appreciate the real importance of this, but it's worth getting correct.
#10 |
And don't be put off... have a go... and there's loads of help on here if you get stuck.
| Some Quad els57 questions! - Novice Questions! | Fanuc | Planars & Exotics | 13 | 5th December 2007 09:26 AM |
| Completed Mauro revc gaincone boards | Ang | Swap Meet | 1 | 25th October 2007 01:00 PM |
| LM3875 power supply questions... | nycavsr2000 | Chip Amps | 3 | 11th October 2006 05:42 PM |
| LM3875 dual mono kit - a few questions. | quickshift | Chip Amps | 17 | 23rd August 2005 12:43 PM |
| lm3875 questions | jimbo1968 | Chip Amps | 6 | 14th June 2005 04:48 PM |
| Page generated in 0.10963 seconds (80.50% PHP - 19.50% MySQL) with 10 queries |
