| Chip Amps Amplifiers based on integrated circuits |
Hello all!
Which of the power op-amps out there would be the best bet for use as it's own active crossover? I'd seen this done in the days of the LM12 and built a few of them for full range use , but have no real knowledge of the newer generation of devices. I had in mind a smallish active setup with an actively controlled 2-way + sub layout, but wonder if the devices would behave themselves. Having baffle compensation and good control of the cone in one fell swoop would probably help my speaker designs sound a wee bit better! TIA Jorge |
#2 |
frugal-phile(tm)
It is an opAmp so, within the limits of its gain requirements, you can wrap a 2nd order Sallen-Key around it, and if necessary add another RC in front to get 3rd order.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
The Overture series ICs as an example all need a minimum gain of 10 for stablility. With a Sallen-Key filter you will have lower gains outside of the passband. The additional effort to compensate for that could be higher than using the filters before the power amp.
Or you would have to find a unity gain stable power opamp. The OPA549 could be such a candidate.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| active crossover help | Andrewbee | Full Range | 4 | 27th August 2005 12:43 AM |
| Help with active crossover | sunil | Multi-Way | 3 | 8th March 2004 10:44 AM |
| XVR1 active crossover, discrete active stage | promitheus | Pass Labs | 18 | 22nd July 2002 01:29 AM |
| Page generated in 0.07476 seconds (77.71% PHP - 22.29% MySQL) with 10 queries |
