Who has ever heard of RCA's HC1000 100W amp Hybrid Chip?
Old 7th May 2010, 02:56 PM   #1
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 Who has ever heard of RCA's HC1000 100W amp Hybrid Chip?
Default Who has ever heard of RCA's HC1000 100W amp Hybrid Chip?
If anyone has ever saw this chip at work, I would be very grateful to know something more about. I think history helps us understand present and future!
Thanks.
Best regards,
Max.
Old 7th May 2010, 03:52 PM   #2
rcbuck is offline rcbuck  United States
Yes, the HC1000 was the early prototype version. It was replaced by the updated HC2500. I don't think many of the HC1000s were produced.
Back in the 80s I worked for a company that used the HC2500 as the output stage of their PA amplifier. They made 3 different versions of the amp (35W, 75W, and 100W) with the only difference being the +/- supply voltage. The 100W unit had a +/- 35V at 5 amps power supply.
I still have a couple of the 100W amplifiers laying around with bad HC2500s in them. The hybrid parts were discontinued years ago. The 100 watt amplifier weighs about 50 lbs. The power transformer is a massive 4x4x3 inch part.
The company produced thousands of the units over a period of about 5 years until the HC2500 was discontinued by RCA. The amplifiers were fairly reliable although they would occasionally fail with power surges or nearby lightning strikes. I would say we saw about a 5% failure rate in the field which wasn't too bad.
I have the original RCA HC1000 (dated 3/72) and HC2500 (dated 9/73) data sheets in my data sheet file folder. Guess I need to get rid of all that stuff from back in the 60s, 70s, and 80s.
Old 7th May 2010, 05:47 PM   #3
Sorry for the bad phrase construction... "has ever saw"!!!
Thanks for commenting!
Best regards,
Max.
Old 10th May 2010, 07:01 PM   #4
sdman is offline sdman
Default Hc1000
Yes I remember the HC1000.
I did have two or three lying around somewhere.
sam
Sam
Old 19th May 2010, 08:38 PM   #5
KAZVARGA is offline KAZVARGA
Default HC2500 - down memory lane
When I worked in Buffalo NY, I remember repairing amps that used these. There were 4 channels in 19" chassis, 2 big E-I transformers. No idea who built them, they were in clubs I serviced in the late 80's. When I could not get more HC2500's, I just used Sanyo hybrids with a few additional parts. I opened up a dead HC2500 once, and it was just an ordinary amp circuit using surface mount parts on a ceramic board. A dead one could be repaired.
Old 19th May 2010, 10:38 PM   #6
geraldfryjr is offline geraldfryjr  United States
yes,I remember that chip (of the day),I saw one once in some amp that all I had to do is just replace the fuse for (repair job) and never saw it again down in naples fl.
I met the guy again a few years later and he said "I'm sorry to say but it bit the big one" I asked, what did you do with it ",he said " I tried ,but I could not find a replacement part for it." I said "ahh man you should have givin it to me because it had such a huge transformer in it" he said "I'm sorry but I wasn't in this area at the time when it blew out and I remembered you ,but I wasn't in the area at the time ,so I ended up thorwing it out"
(bunch of rich people that I had to deal with)
But I remember that that was the awesome chip of the day ,that I so wanted and had all of the specs memorized.
Until the advent of the LM18XX and LM38XX series of chips.
And then SANKEN came along( mid 80's )
p.s. oh yea, he said it blew fuses all of the time ,It really was the only heavy duty chip that was ever produced at that time .jer
Old 1st November 2010, 06:24 AM   #7
zargon1 is offline zargon1  Canada
I have a pair of NOS RCA HC2500 modules if anyone is interested. They are pretty much fool proof and reliable if done properly.
Old 1st November 2010, 06:31 AM   #8
I have about 150 pieces of NOS Signetics NE540H audio power IC's I'd like to sell. These are commonly used in applications for audio driver stages, headphone amps (Boak high quality headphone amp in The Audio Amateur a few years back) and as reverb drivers for instrument amps. They are in a TO-5 package, and offer high quality audio with minimal external parts.
Old 1st November 2010, 06:41 AM   #9
I also have about 60 pieces of the Sanken SI-1025 hybrid power modules. They use good quality internal parts, such as Sony transistors etc., hermetically sealed onto a heat sink base. With just a few external parts, these modules provide surprisingly good sounding audio power amps at an honest 25 watts RMS; far better than than the sound of the inexpensive mass produced power chips you find in most current consumer audio gear. I have about 6 pieces of the SI-1050 50 watt version as well.
Old 8th November 2010, 09:12 AM   #10
supersam888 is offline supersam888  Hong Kong
Default How about the price per each?
Who has ever heard of RCA's HC1000 100W amp Hybrid Chip?Hide this!Advertise here!
Tube/Mosfet 100W Hybrid Amplifier apexaudio Solid State 145 15th July 2015 09:36 PM
Need help fo 100w+per channel stereo chip amp mlaroche Chip Amps 14 12th December 2006 12:20 AM
Evolve Amps 100W+100W Stuff 4 Sale WALTER BURKHARD Swap Meet 4 8th June 2005 10:57 AM
Any designs for tube/chip hybrid guitar amp? leadbelly Instruments and Amps 5 24th November 2003 11:56 AM
Hybrid "SE Tube Amp Sound Style" Chip Amp idea ThorstenL Chip Amps 24 7th February 2003 06:41 AM
Copyright ©1999-2017 diyAudio
