Old 6th May 2010, 08:52 PM   #1
tsharp is offline tsharp  United States
Question Utility amp grounding and sheilding?
I recently purchased a Pyle Pro PCA2 utility amp, i hooked it up to some cheap speakers in my living room and was impressed that there was no hum or hiss. i later set it up on my desk to use with my PC, but now of course there is a very noticeable hum whenever the amp is on. i'm sure it has a lot to do with my modem, wireless router, and LCD being very close to it. i want to know if grounding the amp (comes with 2 pin plug) by replacing the cord and adding a chassis ground would hurt or help the sound.
here's the amp http://www.amazon.com/Pyle-PCA2-40-W.../dp/B001P2VV50
Old 8th May 2010, 08:04 AM   #2
Not likely. You can try the following.
- Connect amp and PC to the same outlet, i. e. use adjacent outlets on a power strip.
- Turn the power plugs around. You may find a combination where the hum becomes less. That worked for my PC amplifier.
- Move the signal and speaker cables around and separate them as good as you can form power cables and devices that have a transformer inside including the very amplifier.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 9th May 2010, 12:56 PM   #3
infinia is offline infinia  United States
infinia's Avatar
Agree with pacific
My experience is the signal wires at the input are the source. Try moving the connectors to gain better contact or replace with HQ cables.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 12th May 2010, 08:09 PM   #4
thanks for the input. i moved the amp underneath my desk and i have it plugged into a different wall socket, i also found a better shielded RCA to 1/8 adapter. now its almost dead silent!
Old 13th May 2010, 09:57 AM   #5
infinia's Avatar
Good to hear you solved it!
AMP ground/Sheilding ali_moinuddin Pass Labs 1 14th August 2008 05:56 PM
OPTs of questionable utility koolatron Tubes / Valves 19 2nd March 2008 04:03 PM
I've misplaced my convert.exe utility dantwomey Multi-Way 3 4th September 2006 08:35 PM
Page generated in 0.07238 seconds (72.82% PHP - 27.18% MySQL) with 10 queries
