Preamp and Chip Amp from same power supply
Old 1st May 2010, 01:21 AM   #1
fingersoccer is offline fingersoccer  United States
Default Preamp and Chip Amp from same power supply
I'm building a Chip Amp based on a LM3875 (from AudioSector.com) and would like to integrate a preamp (the Death of Zen preamp from Rod Elliot's site) using the same power supply as the amp itself.
Is this a matter of making a lead off the PS board and using a couple resistors to bring the voltage to where it needs to be, or should I think about an entirely separate PS board for the preamp?
Thanks!
Old 1st May 2010, 11:12 AM   #2
pacificblue is offline pacificblue  Germany
A separate PS is the solution with the highest potential to sound good. A couple of resistors only is the exact opposite. Depends on your demands on sonic quality. A better approach is to add some voltage regulators. At least use some Zener diodes like Rod Elliott does in Figure 6 in his Project 115
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 1st May 2010, 11:29 AM   #3
Mooly's Avatar
If the supplies are correctly implemented there is no problem using the same supply as the main amp. If the supplies in the main amp effect the preamp then it's the implementation that's wrong, not the principle.
That means suitable regulation, perhaps simple discrete series pass and then an IC or zener shunt if the current requirements are modest.
Grounding is (very very) important too and must be correct.
Old 1st May 2010, 03:30 PM   #4
Ok, thanks for the input.
I want to keep this project as error-proof as possible since I'm new to building amps, so would it be a bad idea to skip the active preamp and instead go for a passive version consisting of an input selector and volume control? I've read different things about chip amps needing an active preamp, people both for and against it. The integrated amp described on the audiosector site doesn't have one, so it seems like it should be fine.
If it is recommended, do you guys have any recommendations about where I can read up on how to implement the single power supply to provide for both boards (the suitable regulation, discreet series pass, zener shunt, and the very very important grounding) as Mooly mentioned?
Many tips of the hat.
Old 1st May 2010, 05:46 PM   #5
A chipamp does not necessarily need a preamp. Try it without first and add the preamp later, if you are not satisfied with the result.
There is a link in my previous post.
Old 1st May 2010, 06:49 PM   #6
Yes, I agree with Pacific.
Learn how to build a simple chip power amp. Find out how you could package it once you see the size of the assemblies. Then think about the extra space needed for the selector/pre-amp stages. Finally buy a chassis to hold a power only amp or big enough for the full integrated amp.
Do the initial bit in small achievable stages.
regards Andrew T.
Old 16th August 2011, 05:26 PM   #7
OK, what about buying a voltage regulator module from eBay (DC-DC Converter Board Voltage Regulator Stepdown Module) to regulate the voltage to the preamp? This seems like something that any idiot could figure out (which is important to an idiot such as myself), but I want to make sure I have the right idea here.
Old 16th August 2011, 05:52 PM   #8
Mooly's Avatar
Quite an old thread...
Not what you want tbh
What are the voltage requirements for the preamp ?
How much current ? Preamps are usually in the 10's of milliamps at most.
Do you want to run it off the main chip amp PSU if possible ?
Old 16th August 2011, 06:19 PM   #9
Mooly, thanks for the quick response.
The preamp I'm planning on building is the Rod Elliot Project 37a Death of Zen Preamp. Current requirement is <10ma, voltage requirement is 15V.
I'm working on an integrated amp, so using the amplifier's power supply would be ideal. I know I need to knock the voltage down to around 15V, but I'm not entirely sure how to do so.
Old 16th August 2011, 06:27 PM   #10
Mooly's Avatar
All you need is a simple zener regulated supply for that current and voltage. It's as easy as it comes and performance is excellent.
Two 15 volt zeners, two resistors and two caps...
I can draw it for you later if no one beats me to it
Preamp and Chip Amp from same power supplyHide this!Advertise here!
Power Supply for multichannel Chip Amp audionut Chip Amps 5 16th April 2010 03:44 PM
Chip amp power supply and pots chris_cosgrave Swap Meet 1 7th April 2010 10:59 AM
Power supply for lm3886 chip amp srinath Chip Amps 10 31st March 2010 07:54 AM
Power Supply for Chip Amp quickbrownfox Chip Amps 13 6th October 2007 10:26 AM
Chip Amp as tracking supply for preamp drdagor Chip Amps 2 10th July 2004 11:53 AM
