The Fuses Just Keep Blowing The Fuses Just Keep Blowing - diyAudio
Old 17th June 2003, 03:03 AM   #1
raffir is offline raffir  Canada
Default The Fuses Just Keep Blowing
I've been trying to construct a power supply for my Gainclone. Every time I plug it in, it blows a fuse. Right now, the schematic is as follows.
T1 is a Plitron 225 VA transformer with 15v secondaries.
F1 and F2 are slow-blow 4A fuses.
BR1 and BR2 are 50V fast rectifiers, I think.
How must I hook them all up to have the power supply work and be Gainclone-worthy?[IMG]ps1.jpg[/IMG]
Old 17th June 2003, 09:51 AM   #2
carlosfm is offline carlosfm  Portugal
Banned
raffir,
You just need one fuse one one of the wires of the transformer's primary.
On the other wire you can put a 10ohm/7w resistor, because toroids have a big in-rush current at turn on, and that's what may be blowing your fuses.
Then you can use a 2A fuse, because 4A is too much.
Old 17th June 2003, 10:01 AM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
4 A slow should work but I sucpect that you have connected the primary wrong. Do you have any 12 or 24 VAC? If yes, use this voltage as test voltage.
You could have connected the primary windings so they cancel out the magnetic field = short circuit more or less.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 17th June 2003, 10:08 AM   #4
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Please see HERE
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 17th June 2003, 04:21 PM   #5
GringoAudio is offline GringoAudio  Canada
Unhappy Yeah look at the Primary connections again(nt)
The connections to the primary circuits of your transformer might be the problem as your power supply concept is fine.
Old 17th June 2003, 04:33 PM   #6
Banned
Looking again at your schematic...
Is it 4 wires you have on the primary?
Aren't you connecting 115v and 230v primaries at the same time?
Old 17th June 2003, 04:40 PM   #7
JOE DIRT® is offline JOE DIRT®  Canada
JOE DIRT®'s Avatar
your rectifiers are not wired properly...you have a dead short right now on the secondaries
DIRT®
Old 17th June 2003, 04:47 PM   #8
Banned
DIRT®
Where, where??!
It's too dense around here...
Old 17th June 2003, 06:13 PM   #9
Kermit is offline Kermit  Norway
Kermit's Avatar
Your bridges look fine to me, that’s the way I did it in my Aleph.
Are you sure your primary side is wired correctly? Referring to plitron’s website (http://www.plitron.com/pages/Products/Std/schemati.htm) for 115v operation the black and brown wires should be joined and connected to neutral, and the white and orange connected to hot.
Do you have anything connected when the fuse blow?
Sven Sřdem
Old 17th June 2003, 06:31 PM   #10
JOE DIRT®'s Avatar
maybe I`m not reading his schematic properly but his + and - on the bridges are connected
The Fuses Just Keep BlowingHide this!Advertise here!
Keep Blowing Fuses Whiting Tubes / Valves 9 11th September 2008 09:44 PM
Car Amp help? Fuses blowing... Tolo Car Audio 1 3rd December 2007 01:42 PM
Help, new PSU blowing fuses TDWesty Chip Amps 14 4th March 2007 07:29 PM
Blowing fuses balance Tubes / Valves 2 5th March 2005 02:16 AM
blowing fuses homegrown45167 Car Audio 2 22nd October 2004 12:16 PM
Copyright ©1999-2017 diyAudio
