| Chip Amps Amplifiers based on integrated circuits |
Gentlemen...
I am going to build a 6 channel chip amp ampliphier. This will be for a Bi-amped system. I have a rather good sized Signal transformer that I would like to power all 6 channels from. I would think that regulating the power supply to all 6 six channels would be a good thing so I don't get crosstalk between the channels through the power supply. I have read that descrete regulators sound better in the chip amp than the pre packaged chip regulators. The BOSOZ pre-amp uses a simple descrete mosfet follower type of regulator...Would this be sufficient for a Chip Amp?? |
#2 |
the problems that multi-channel amplifiers have mostly stem from the shared Audio Ground and the need to connect that Audio Ground to Safety Earth.
Regulated PSUs do not solve that problem. Bi-amping, one pair of stereo speakers or three sets of two way? Put an amplifier at each speaker not a multi-channel in a central remote location.
regards Andrew T. |
#3 |
Andrew...thanx for your response...Each speaker will be woofer tweeter woofer. I like it when each driver has its own channel. I use a passive filter before the ampliphier.
I was thinking of a regulated supply because chip amps are supposed to sound better with a discrete regulated supply. I was hoping to get away with one big transformer, which I already have. Now...you mentioned Audio ground sharing the Safety Earth. For better or worse, I have not been using a safety earth. |
#4 | ||
You basically have two options. Safety earth or double insulation. Safety earth is easier to get right.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#5 |
thanks for your reply...
I have already gone the "no part left behind" route with a bi-amped system using 3 Aleph 30's, where each driver/channel does get its own transformer/power supply. The results are really good and thoroughly worthwhile. I was thinking of a system that doesn't have to be "over the top" but decent....for a vacation house... |
#6 | |
Please refer to this diagram from Rod Elliot. This way you avoid a ground-loop and still have a safe safety earth. This is how Bryston does it as well, and they are silent amps without hum/buzz or hiss. With kind regards, Bas |
| Chip amp power supply and pots | chris_cosgrave | Swap Meet | 1 | 7th April 2010 09:59 AM |
| Power supply for lm3886 chip amp | srinath | Chip Amps | 10 | 31st March 2010 06:54 AM |
| FS: chip amp power supply and xformer | madisonears | Swap Meet | 3 | 3rd March 2009 04:39 AM |
| Power Supply for Chip Amp | quickbrownfox | Chip Amps | 13 | 6th October 2007 09:26 AM |
| Computer Power Supply for chip amp? | skenwrick | Chip Amps | 2 | 7th February 2006 12:56 AM |
| Page generated in 0.09099 seconds (75.58% PHP - 24.42% MySQL) with 11 queries |
