| Chip Amps Amplifiers based on integrated circuits |
What amp should I choose to make?
My compact stereo have developed quite a bad hum, even with no input and the volume turned all the way down. So naturally I want to build my own. I can solder and have some training in electronics, but that's about it. I have researched different kits a bit, chipamp.com & audiosector.com, which seems like nice kits, but I'm feeling too inexperienced to be sure about what to buy. I have a pair of Dali Concept 1's: 8ohm, 87db. From what I've read about them 20w. should be enough for our room, but that's a guess on my part ![]() What I would like is an amp that plays well with my speakers, has a thorough guide (including powersupply) and is simple to build. A volumecontrol would be nice as well. Does anybody have any recommendations? |
#2 |
go to decibel dungeon. read.
go to ESP. read. search this Forum. read. As a side note, my opinion is, that 87dB/W and chipamps are not a good combination.
regards Andrew T. |
#3 |
Thanks Andrew. I hadn't found the ESP site before you mentioned it. I have, however, read a lot on Decibel Dungeon and here.
Why is my speakers and chipamps not a good combination? Sound quality? What kind of amplifier should I be looking at instead? I liked the simplicity of the chipamps. |
#4 |
I too like the simplicity of chipamps.
But, I find the current limits in chipamps cripple the potential performance of the system when low efficiency speakers are used at anything above normal conversation level. Quite adequate for background music while washing the dishes. Wait till you see the flames/grenades fly!
regards Andrew T. |
#5 |
Soakin' up the Sound!
I built an AudioSector LM3875 amp. The online support, especially from Peter Daniel, was excellent. As far as speakers for it; I built a pair of Fostex FE127 Fonkens. This set-up works great together.
I don't know what your listening requirements/habits are, but I like a wide variety of music and I listen in a carpeted room that's approximately 12x16x8. Mike
#6 |
I could always build a chipamp, and then have an excuse for building a set of speakers.
(Nobody tell my girlfriend I said that )I'll check out those speakers, Mike. |
#7 |
To build an amplifier around a driver chip (LME49810 and brothers) and a discrete output stage is worth to be considered too IMO. The amount of power is scalable and implementation is quite simple.
See datasheets and several threads about here. |
| Chip amp power supply- a beginners guide | Nuuk | Chip Amps | 702 | 20th May 2012 05:48 PM |
| Beginners first amp - what to choose? | Nis | Chip Amps | 1 | 13th April 2010 11:11 AM |
| Chip amp for Beginners, LM4766 | dukep | Chip Amps | 11 | 23rd February 2010 02:42 PM |
| Beginners Guitar amp project, any suggestions? | weatherlight | Instruments and Amps | 19 | 11th August 2008 10:17 PM |
| Page generated in 0.07812 seconds (80.25% PHP - 19.75% MySQL) with 10 queries |
