protecting my speakers from my GC protecting my speakers from my GC - Page 2 - diyAudio
Old 16th June 2003, 12:53 PM   #11
Matttcattt is offline Matttcattt  England
Matttcattt's Avatar
always check input and output, and use a test driver, not your best sreakers. :P
i always do, and ive mever blown a speaker.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 16th June 2003, 02:32 PM   #12
carlmart is offline carlmart  Brazil
Default Re: protecting my speakers from my GC
Originally posted by damitamit
After blowing up the crossover and drive unit on one of my Kef Q1s with (i think) my gainclone. well im sure it was my gainclone.
How do i protect my speakers from any other gc mishaps?
would just putting a fuse at the speaker terminals work? what sorta amperage?
btw, what couldve caused the speaker to blow. it was playin at low volume..
Have you checked what happened AFTER the fact?
Did you check DC offset and what did you get?
A fuse will not protect from DC, only from higher levels. Unfortunately the woofers are the ones to go when DC is present, because tweeters usually have a blocking cap.
What did you blow on your Kef? If it's the tweeter then you had oscillation or high level probably.
In any case I have not seen threads on this Forum that deal with the need to protect our speakers and still have a good sound.
Carlos
Old 16th June 2003, 03:40 PM   #13
damitamit is offline damitamit  United Kingdom
thanks for the replys!
I havent infact checked the amp after the incident. I had to go away for a few weeks and now im back, looking at it again.
The woofer blew on the Kefs.
What do you mean by the DC offset? is it just the dc at the output terminals?
btw, i did test first with a crap speaker. The amp was running fine so connected up the Kefs. They were running fine for a hour or so until this happened...
thanks
Amit
Old 16th June 2003, 03:46 PM   #14
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Please read THIS
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
protecting my speakers from my GCHide this!Advertise here!
Protecting a microcontroller rtarbell Parts 10 11th January 2008 01:23 AM
protecting a VR tube jarthel Tubes / Valves 14 10th May 2007 12:21 AM
why is my amp protecting? mbugua Class D 2 19th January 2007 12:58 PM
protecting mosfets in UcD zilog Class D 10 12th November 2006 07:52 PM
Protecting speakers against dc with mute? soundNERD Chip Amps 11 21st March 2004 11:52 AM
Copyright ©1999-2017 diyAudio
