protecting my speakers from my GC - diyAudio
Old 15th June 2003, 06:38 PM   #1
Default protecting my speakers from my GC
After blowing up the crossover and drive unit on one of my Kef Q1s with (i think) my gainclone. well im sure it was my gainclone.
How do i protect my speakers from any other gc mishaps?
would just putting a fuse at the speaker terminals work? what sorta amperage?
btw, what couldve caused the speaker to blow. it was playin at low volume..
thanks
Amit
Old 15th June 2003, 06:50 PM   #2
elizard is offline elizard  Canada
Send a message via MSN to elizard
its not simple as a fuse ..
i found there isn't a need, but you can check out some speaker protection circuits
rod elliot has one on his site, velleman has one ..
check your dc offset btw
Old 15th June 2003, 06:55 PM   #3
diyAudio Moderator Emeritus
jean-paul's Avatar
Velleman K4700 speaker protection kit is OK.
It's only audio. Member of the non modular PCB design committee
Old 15th June 2003, 07:02 PM   #4
http://www.velleman.be/common/product.Aspx?id=9233
http://www.qkits.com/serv/qkits/vell...ages/K4700.asp
that's for the velleman kit
http://sound.westhost.com/project33.htm
that's rod elliot's link
Old 15th June 2003, 07:02 PM   #5
Of course you must know what you want to protect the speakers
against: DC, oscillations or just too high power?
Which of these things do the Elliott and Velleman kits check?
Edit: OK, oscillations are mostly interesting to detect to protect
the amp, since a Zobel filter should do the job of protecting the
speakers.
Old 15th June 2003, 07:07 PM   #6
speakers.
i don't think he's trying to protect against high power either, since he said he's playing at low power
i'll guess its dc that blew it
as i suggested, check your dc offset .. make sure its low .. mine's at 28mV w/o any problems
Old 15th June 2003, 07:22 PM   #7
Yes, it was hardly high power that blew it in this case. For some
people it might be useful with such protection, though. My
comment was merely a reaction to the fact that people often
speak about speaker protection, without specifying what kind
of protection they mean.
DC is a good guess but I suppose it could be oscillations too,
at least it there is no Zobel filter. Did the amp get hot??
BTW, one must not forget that statistically, things do occasionally
break without any obvious reason, which could depend on
manufacturing defects, fatigue etc. I blew a speaker once
for no apparent reason. I had used the same speakers and
amp for three or four years without problem, and I didn't play
particularly loud. I replaced the faulty element and it never
happened again.
Old 15th June 2003, 07:23 PM   #8
Thomas is offline Thomas  Denmark
Thomas's Avatar
It must be DC he's talking about...
If you forget to connect (or it breaks later) Vin+ to ground you almost get clean rail voltage at your Vout and Vin- ! Happened to me once. (It's the inverting design I'm using.) I was sensible enough to meassure the creature before connecting it to anything, so no harm was done.
Old 16th June 2003, 07:57 AM   #9
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
And that's only one way to get nasties on the output! The negative rail connection from my PSU to amp broke and that put 36VDC on my terminals. Like Thomas, I was lucky enough to have tested the amp before connecting the speakers!
I've been testing my GC's with old or cheap speakers so far but will revert to using my Velleman protection modules before connecting up my precious Goodmans 201's.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 16th June 2003, 08:25 AM   #10
analog_sa's Avatar
When a load is connected and negative power is missing the protection circuit of the chip kicks-in pretty fast. I would expect most reasonably powerful speakers to be safe. It will be interesting to see how much the relays in your Velleman will affect the sound quality. If the relays i've tried in the past are similar - a lot.
cheers
peter
Protecting a microcontroller rtarbell Parts 10 11th January 2008 01:23 AM
protecting a VR tube jarthel Tubes / Valves 14 10th May 2007 12:21 AM
why is my amp protecting? mbugua Class D 2 19th January 2007 12:58 PM
protecting mosfets in UcD zilog Class D 10 12th November 2006 07:52 PM
Protecting speakers against dc with mute? soundNERD Chip Amps 11 21st March 2004 11:52 AM
Copyright 1999-2017 diyAudio
