| Chip Amps Amplifiers based on integrated circuits |
I got a TDA 7377 that I'm thinkin of using for a headphone amp.
Can you use a chip designed for 4 and 8 ohm speaker loads for a headphone application? I know this chip is over-kill, I will run it at a min. voltage. The chip is 2x20w @ 4ohm or 4x6w @ 4ohm, actually there is lot's of ways to wire the bridgeable 4 channel amp. It takes a regular 12V power supply, not building a portable amp so power consumption is not a concern. I've got all the parts I beleive. I could build a moderate stereo amp, or a kick-butt headphone amp. Since the ohms increase with headphones, I assume the wattage used by the chip would be less? |
#2 |
Yes it will work, but as you say is overkill and not ideal.
You will need to pad the outputs with series resistors to bring the level at the phones down (and also the noise from the chip), just as in a normal socket on a "normal" amp. Suggest something around 120 to 330 ohms for starters.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
I guess I could use a variable resistor of sorts, to try a few values.
When I "pad" the output, do I connect the resitor to ground, or in series with the speaker? |
#4 |
Tyler |
#5 |
For simplicity I meant just in series, which is what the majority of amps with a headphone socket do.
Redshifts187's link is great... that's a better way as it provides a more constant and known output impedance, and you have said power consumption isn't an issue. So why not try both methods and see what you think
#6 |
Thanks uys, I will try both.
I thought I would use this chip because it sounds good and thought by downsizing the load to headphones it would maintain or raise the fidelity, as it can drive the headphones effortlessly. It has 0.03 THD at 2ohms 0.02 THD at 4ohms 0.?? THD at headphone impedances. Is this an accurate assumption, or am I making the fidelity worse? |
#7 |
Basically correct
![]() It's not just about pure numbers as to how something will sound anyway, re the valve amps that sound totally effortless and musical despite having distortion perhaps approaching 50 to 100 times the levels you quoted. It's the type of distortion, the spread of the harmonics etc that really colour and define the sound... and often we like that... and prefer the amp with the higher levels. Class b output stages and long tailed input pairs tend to generate odd harmonics the amplitude of which rises rapidly with increasing frequency which isn't good, however your chip being so lightly loaded this is hardly an issue.
#8 | |
Background noise, speaker amps tend to have more of it than headphone amps. That's why the resistor in series is needed - to waste that noise. |
#9 |
To bad my TDA7377 Datasheet does not have any graphs.
| How to connect 62 ohm headphone to 8 ohm output | Sunsun22 | Headphone Systems | 15 | 16th June 2007 01:29 PM |
| Chip Amp for 4 ohm Center? | SilverJS | Chip Amps | 4 | 17th May 2007 10:11 PM |
| Best Chip amp for this 4 Ohm speaker | 100db | Chip Amps | 14 | 29th September 2006 12:45 AM |
| Is it Chip or BJT in this Stereo Amp? | boxedin | Solid State | 4 | 25th December 2005 02:44 PM |
| Good & simple chip amp for 2-ohm load? | Otherwise | Chip Amps | 7 | 8th July 2003 07:21 PM |
| Page generated in 0.09670 seconds (78.71% PHP - 21.29% MySQL) with 10 queries |
