| Chip Amps Amplifiers based on integrated circuits |
I am designing a pre-amp circuit based on opamp (OPA134), but I'm not wearing any compensating... This circuit also does not use:
HeadWize - Project: Designing A Pocket Equalizer For Headphone Listening (A HeadWize Design Series Paper) Will it have any problem? (Attached) Thanks |
#2 |
The OPA134 is unity gain stable. It looks like you are running a gain of about 12 dB. So you should not have stability problems.
However, your sim shows a bandwidth of almost 5 MHz. I suggest limiting that to 200 kHz or so by adding a capacitor across the feedback resistor and by adding an RC filter on the amp input. There's no reason to amplify noise in a bandwidth you aren't using. ~Tom |
#3 |
I have found that I like the power amp set to F-3dB~200kHz using a single pole RC input filter.
I have also found that using a wider bandwidth on the preamp maintains that nice sound at the speakers. I normally aim for ~1Hz to 300kHz in the pre-amp to feed a power amp @ 1.7Hz to 200kHz. The result is ~ F-1dB @ 3Hz to 100kHz. This seems to suit me, my speakers and the various interferences existing in the house.
regards Andrew T. |
#4 | |||
I am using 3 opamps, two in unity gain and the last with a gain Quote:
Is that my amp already has an RC filter in input, so I asked if it was absolutely necessary. This is another preamp without concern RF: Hi-Fi Preamplifier but other preamp to book D.Self, has compensating: |
| Frequency Response Program | jwmbro | Multi-Way | 6 | 4th January 2008 12:12 PM |
| Frequency response | 2litre | Analog Line Level | 5 | 31st May 2006 07:00 PM |
| frequency response | pmarcouxx | Digital Source | 2 | 20th July 2005 07:43 PM |
| Doubts on Phase Response and Frequency Response | dumrum | Multi-Way | 11 | 5th April 2004 10:39 AM |
| frequency response in Excel | Milzie | Multi-Way | 4 | 12th December 2002 10:45 PM |
| Page generated in 0.07720 seconds (73.03% PHP - 26.97% MySQL) with 11 queries |
