Old 6th April 2010, 03:01 PM   #1
PedroDaGr8's Avatar
Default What OpAmp for CMOYbb?
Well I am considering making the plunge and building my own amp. I figure for my first amp, I am going to build something insanely simple like a CMoy. What OpAmp would you recommend for someone who listens to Electronic, Downtempo/ChillOut/Ambient Jazz, Hip-Hop, Hard Rock and a bit of classical? Maybe those styles are too varied to be held down to one. If so, then divide it up and suggest multiple OpAmps (just let me know which one is best for which style).
I have seen suggestions ALL over the board and have heard certain opamps are better for certain styles, but am having a hard time figuring out which goes with which.
Also, this CMoy is not going to be portable (hopefully, that isn't the CMoy's only advantage) so I can use higher voltage supplies for the OpAmp.
Lastly, the headphones are Koss Pro3aa titaniums, which have an impedance of 60ohms and a sensitivity of 100db SPL/mv
Old 8th April 2010, 04:47 AM   #2
PedroDaGr8's Avatar
Anyone? Otherwise, what is important in an opamp that would help me start narrowing down the list. I plan on purchasing multiple OpAmps to try out (up to I think 8-10 but as few as 4).
Any suggested fav's then if the above question can't be answered?
Old 8th April 2010, 05:39 AM   #3
I just tried a few that I had. I use a 5128A. Sounds good to me. Not much help I know.
Old 8th April 2010, 05:59 AM   #4
Beftus is offline Beftus  Netherlands
Beftus's Avatar
Try an OPA2132 or OPA2134 for starters. I also have a AD8066 on a Doc Brown™ adapter.
Which opamp to use? Carnesd Solid State 16 4th April 2010 03:04 AM
Help about OPAMP nandax Chip Amps 9 28th October 2008 02:34 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Which OPAMP kestrel200 Solid State 14 23rd August 2005 09:20 PM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 10:49 AM
Page generated in 0.07507 seconds (73.37% PHP - 26.63% MySQL) with 10 queries
