What wattage?
So you have 6 outputs? 3 stereo plugs?
Your wattage will directly decide on what you are going to get. And how small you want it.
There are car audio amp chips that have 4 amps per chip, but low wattage, or you could use LM1875 chips, or LM3886s, which are both single amps per chip.
There is a huge range out there Vader, so yea, you need to really say how much wattage you want out of your amp.
DIY AUDIO TÜRK?YE • Ba?l?k görüntüleniyor - 5 Kanal LM3886 uygulamas?
This is my 5 channel application. PCB etc everythğing included..
Enjoy!
Enjoy!
hi.
I want 5.1 channel integrated amplifier. use with htpc
What speakers? What size is the room? How loud does it need to play? Got a budget?
Enjoy!
He needs a 5.1, which is really six, the last one being for a subwoofer amp, and is often more powerful then the first 5.
In my computer based application, i have used LM3876 amps in low voltage arrangement for driving 4 ohm loads, and then a discrete 200 watt amp for the subwoofer channel.
The 5 channels all drive 4 inch car speakers in small cabinets i made, and the subwoofer driving twin 8 inch sub drivers in a 44 litre cabinet.
Sorry this is my fault..
Actually the project includes a subwoofer amplifier also that;
DIY AUDIO TÜRK?YE • Ba?l?k görüntüleniyor - JBL GT5-12 ile aktif subwoofer projesi..
An active sub filter, a phase corrector (0-180°), a infrasonic filter and a bridge driver for each PA100 board... It can useable anykind of 12-15" sub driver in a sealed box!
By the way you must make two of PA100 amplifier..
So as a conclusion, you will have a 5.1 amplifier which 4x65W sats and a 200W subwoofer.
Is it enorugh?
Is it enorugh?
