| Chip Amps Amplifiers based on integrated circuits |
Hi guys,
Sorry I am a newbie In the field of amplifiers, So sorry If my questions are stupid. I have designed a stereo amplifier using 2 LM3875. Now I want to know the miniumum of potentiometers I need for a such amplifier? my guss is that I need a dual gang pot for Left/ Right speakers, and maybe another pot (do not know which kind) tp control the volume of both speaker simultaneity, right?? Any other pot needed? for now I have no intention to add a tone control in my design. Thanks a bunch for any help? |
#2 |
If you're not going in for any tone controls, then all you need is a volume control. You can either use a ganged pot to control the levels of both channels at the same time or you can use two single pots to control the the channels individually.
Hari |
#3 |
The minimum number of pots is two. A simple pot is used on each channel for L and R volume control. But then it requires two hands to control the amp's volume. If you don't like using two hands you could use one dual gang pot for one-handed control.
But with the dual gang volume control you can't adjust the relative volume of the two channels. So you may (or not) want to add a "balance control" which is just a dual gang volume control with linear taper and one side wired "backwards". A lot depends on what controls, if any you have on the preamp. I'm working on something now that will only have trim pots inside and zero external controls. Think about how you will use the amp Many people will use the two handed system because it uses the minum number of parts and every part adds noise and degrades sound even f just a lttle and every part certainly adds cost and work to the project. |
#4 |
an integrated amplifier, containing both the pre-amp and the power amp has a volume control.
A power amp normally has no volume control. All the control functions are usually in the pre-amp.
regards Andrew T. |
#5 |
| Crown IC150 level pot needed ? | thermal runaway | Solid State | 0 | 28th August 2008 02:32 PM |
| Hook up pot help needed | DeanP | Chip Amps | 1 | 12th June 2007 01:11 PM |
| 1 meg audio pot needed | danielm | Vendor's Bazaar | 1 | 12th February 2007 05:15 PM |
| Switched Pot Source Needed | Trout | Tubes / Valves | 1 | 9th June 2006 01:42 PM |
| 4 gang pot / trimpot needed | deandob | Swap Meet | 1 | 26th April 2005 11:52 PM |
| Page generated in 0.07665 seconds (76.90% PHP - 23.10% MySQL) with 10 queries |
