Old 2nd April 2010, 01:04 PM   #1
Default Stereo problem
Hello guys,
I tried to design a stereo amplifier using 2 LM3875 chips.
The power supply is a 50V transformer.
The first problem I am facing is that I have the left output audio in the right output speaker and vice versa, It is weak but considerable.
Can you tell me the reason and the soultion of the said problem please?
THANKS.
Old 2nd April 2010, 06:03 PM   #2
gfiandy is offline gfiandy  United Kingdom
Audio Engineer
gfiandy's Avatar
You have crosstalk, this can occur in may places and without a circuit diagram, PCB layout and photos of the actual design it will be very hard for people to help you.
The most common reason for this is shared ground(0v) returns so look for that first.
Andrew
Old 2nd April 2010, 08:22 PM   #3
Ok thanks for your help.
How can I trim the said problem please?
And how can I solve the shared ground problem too? Can I use bigger capacitors between ground and +/-??
Old 2nd April 2010, 08:28 PM   #4
I have even noticed that the place of one output pins (the ground one) is important to causes or removes the humm noise I hear in the speaker, How can I find out the best place for it too?
P,S Can somebody please introduce me a schematic based upon LM3875 as an stereo Amplifier? I want to trim my design by an sample one too to remove such problems.
Old 4th April 2010, 05:09 PM   #5
boholm is offline boholm  Denmark
boholm's Avatar
The data sheet of LM3875 contains a schematic:
http://www.national.com/ds/LM/LM3875.pdf
Or you can do a search on "LM3875" and get lots of information.
A suitable power supply could be this:
Power Supply for Power Amplifiers
Or this:
Solid State Power Amplifier Supply Part 1
Best regards
Bo
Stereo bass problem Eriksonas Tubes / Valves 3 18th May 2009 04:01 PM
Stereo Chorus 212 foot switch problem? fender62 Instruments and Amps 0 21st September 2007 11:58 AM
LM3886 Stereo Amplifier problem Razbi Chip Amps 8 10th October 2006 01:01 PM
Fisher 800C FM Stereo problem Glowin Plates Tubes / Valves 5 2nd April 2004 10:46 AM
Page generated in 0.07431 seconds (72.01% PHP - 27.99% MySQL) with 10 queries
