New Gainclone Prototype - Page 2 - diyAudio
Old 25th June 2003, 06:32 AM   #11
analog_sa's Avatar
Yo~! Guys...any one tried Mylar caps?? they are called polester caps as well...cheap though....
Yup. We know what are polyester caps. The perfect choice if you aim for cheap sound
Old 25th June 2003, 06:56 AM   #12
li_gangyi's Avatar
Hmm...meaning it would be good as well...for a cheapo one at least...I have built some tube amps..and I always use Mylar caps...better than those crappy wax paper caps I always see...and they melt when u apply solder near to their "ends"...I guss I will go with Mylar caps..I'm on a really limited budget here...just ordered for some LM3875TFs...insulated tabs...hehehe...I gonna kick a** (self-censoring)
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 25th June 2003, 08:02 AM   #13
analog_sa's Avatar
Well, there are many ways to kill the 3875 sound... Can't you at least manage a WIMA MKP4? I use no cap as preamp is either cap or transformer coupled.
Old 25th June 2003, 09:01 AM   #14
li_gangyi's Avatar
Where in Singapore would be the best place to get quality input caps?? I got the LM3875 free as a sample from National Semiconductors...resistors I plan to use 1% metal film and Panasonic alumninium electrolytics...any reason why not to go with RubyCon caps?? I heard they are bad...wonder why??
Old 25th June 2003, 09:27 AM   #15
Banned
Originally posted by Nuuk
(or nothing at all if there is no DC from the source).
Hi Nuuk.
Have you tested it?
I did.
With no DC from the source and no input cap, source playing, no input cap and measuring DC: as the music is playing, DC varies from a few mv to about 900 mv!
I wouldn't advise to use a GC with no input cap.
mdlover, good one, and a good first prototype.
But let me give you a suggestion: put the PSU caps closer to the chip, it has long pins, you can cut them.
P-P is definitely not for me, I do smaller and tighter with breadboard.
Try the LM3875, you'll have a surprize.
As a matter of fact, I'm doing things the other way around: first, the LM3875, then the LM3886 and yesterday I made a little board with two LM1875s.
My idea is to make what will probably be the smallest GC in the world.
Went to bed at 2 am, two resistors before finishing it.
Old 25th June 2003, 10:03 AM   #16
analog_sa's Avatar
Carlos
Do you realise the above does not actually make much sense? Whether the cap is in the source or in the amp, or there is some other way of blocking dc you get a pretty stable offset , whether music is playing or not. I have tested the variations of offset with temperature and they're very minor. How did you conduct your measurement?
cheers
peter
Old 25th June 2003, 10:17 AM   #17
Banned
Originally posted by analog_sa
Carlos
cheers
peter
I had around 28 mv on one channel with the LM3886.
I wanted to try, and shorted the input cap with a wire.
DC was the same.
I pressed play on my portable MD player and measured as the music was playing.
And I measured huge variations in DC offset.
Test it and you'll see.
I think these chips really need an input cap, as normally bipolar devices do.
Maby the Fet-input OPAs don't.
Old 25th June 2003, 11:36 AM   #18
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Hi Nuuk. Did you try it?
Hi Carlos, No, I wasn't saying that I used no DC blocking cap but several people on these forums have done away with one.
Your findings are interesting although I can't really understand why the DC offset should vary by so much! Like analog_sa, I would have thought that if you have a DC blocking cap somewhere in the line, it shouldn't make much difference where it is.
Could this be something to do with connecting to a portable device?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 25th June 2003, 12:20 PM   #19
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
DC was the same.
Something wrong with your source. Some players pass DC when they in active mode. Normally the DC offset shouldn't go that high. I am also not using coupling cap and don't have any problem with excessive DC offset.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 25th June 2003, 02:00 PM   #20
Banned
For testing purposes I use the headphones output or my portable minidisc, as it allows me to control the volume.
Maby I should stop fiddling around and connect the line out to a pot and then to the amp modules while testing.
I have to test that again, because I it doesn't make any difference on the final DC, I will remove the input caps on my GC.
All my sources have output caps.
my new prototype zilog Power Supplies 5 25th September 2008 05:03 PM
prototype PCB's in the US mikelm Solid State 4 6th September 2006 01:20 AM
LM3886TF Gainclone prototype questions ObliVion Chip Amps 13 25th July 2004 05:25 PM
Prototype gainclone, pls comment/criticize ;) mAJORD Chip Amps 6 25th April 2004 10:00 AM
Copyright ©1999-2017 diyAudio
