Old 1st April 2010, 03:43 PM   #1
srinath is offline srinath  United States
Default Input voltage range for lm3886 amp
What would be the input voltage range of a lm3886 amp.
I have one that asks for a 28V-0 -28V AC - so just a transformer needed. Now sadly that costs 45 bucks and ship.
I am finding 24V center tap as well as 36V very cheap. Like 10-20 bucks.
Would either of those work ?
Thanks in advance.
Cool.
Srinath.
Old 1st April 2010, 04:04 PM   #2
ChrisA is offline ChrisA  United States
Thanks in advance.
Cool.
Srinath.
Think of a 36V center tapped transformer as being 18-0-18 and the 24V CT as 12-0-12.
Yes they can work it the curent rating is what you need but you will get a lot less power from the amp if yo run at the lower voltages
Old 1st April 2010, 04:14 PM   #3
I meant to say 24v - 0 -24v. So center tapped 48 I guess.
Now 24V I can get with good amperage ... up to 5-6 amp easy. Would that work.
Cool.
Srinath.
Old 1st April 2010, 04:45 PM   #4
Generally you want 200va or higher for a stereo lm3886 setup. If its stable at 5 amps they would work and be about 200va. You would need 2 identical 24vac transformers at 5amps each.
Old 1st April 2010, 04:58 PM   #5
So a center tapped 48V and atleast 5 amps will work ? K I'll check it, I am sure I can find it. Is 36V - 0 -36V likely to be too much ? I could get a smaller amp rated transformer with 36 ? but am I likely to burn up stuff wiht 36.
Thanks.
Srinath.
Old 1st April 2010, 07:27 PM   #6
Its a math game. You have to keep the output current within limits using your supply voltage. so your current limit is 10amps
Your power input limit is 85vdc rails. So 28vac secondaries is about the limit, which is 79vdc.
8ohm speakers 10amp limit is 80vdc rails or 28vac secondaries
The va for the transformer is for stability. Making it smaller doesnt help anything.
Old 1st April 2010, 08:29 PM   #7
OK so ... well ... I'm confused here.
I should only stay with 28v-0 -28v. Not do 24v - 0 -24v ...
Cool.
Srinath.
Old 1st April 2010, 09:05 PM   #8
godfrey is offline godfrey  South Africa
No, 24-0-24 is perfect.
Nightanole was just calculating that the biggest you can use is about 28-0-28 (so 36-0-36 is too much).
Regards - Godfrey
Old 1st April 2010, 09:23 PM   #9
Regards - Godfrey
Yes 24-0-24 will work.
But with some extra effort you could built a regulated power supply from the 36-0-36 transformer. The regulator would drop the voltage to exactly what's needed and improve the overall sound of the amp somewhat. But a regulator more than doubles the complexity of the power supply, creates heat and uses more power.
Old 3rd April 2010, 03:47 AM   #10
Isn't this a kick in the pants. I found a 28.2V AC power supply. Its called a 00f3058 or ltps 3058. In many ways when I used to find bike parts I would generally not look for what it is, I would look for "what else" is it. I know its a handle bar master cyl holder for a savage suzuki - 1 inch bar, but a lot of car cam shafts have a 1 inch journal dia and many have the same bolt spacing. Hence I ran a car cam journal for my brake master cyl holder.
Anyway its got 28.2 between pin 4 and 5 and 7.2 V between pin 8 and ground.
I need 6.3 - 8 v ac for warming the tube. I can run that between 8 and ground right ?
Now for the 28 - 0 -28 can I run another one of these with a 4 from this, 5 and 4 of the 2 twisted together for the 0 and the 5 from the other one as the - 28 ?
I should put pics up but on this thing there are a few little fuse types on the input side and a capacitor about medium sized on the output side. What does that do, and do I have to cut them all out and just use the transformers ?
Cool.
Srinath.
Sound card input voltage range? J.R.Freeman PC Based 6 17th March 2010 09:16 AM
Max voltage input lm3886 baene123 Chip Amps 4 10th February 2010 01:04 PM
Balanced & Unbalanced input with LM3886 chipamp.com JohnnyP00 Chip Amps 5 17th January 2010 02:33 AM
About Op-Amp input range xiaonan Parts 8 24th October 2006 06:49 AM
High input level LM3886 amp ? bibster Chip Amps 2 13th October 2006 07:13 PM
Page generated in 0.10485 seconds (77.34% PHP - 22.66% MySQL) with 10 queries
