Old 1st April 2010, 01:08 PM   #1
Default How to bridge a HK amplifier ??
Hi
Please forgive me if this is the worng forum, Ihave lookt around but couldnet find any better.
I want to build a new sub, I will use my sub-out from my 6.1 amplifyer (will cut at 90Hz). I will however need an amplifyer to this, as the sub-out are low-level. I have an old HK amplifyer I want to use to somthing, it is an quite old 2channel amplifyer. Is it someway I can bridge the two channels into one?
My initial ide was;
low level from 6.1 amp -> splitt to two signals (L&R) -> L&R input to 2ch amp -> speaker output to sub (+R & -L), but is it even possible to to like this? i am new to the electronics of amps...
BR / T
Old 2nd April 2010, 07:04 AM   #2
ryan750 is offline ryan750  Philippines
hi there, is your amp capable of driving lower loads. Ff you don't still have the sub, try to look for the one that comes with 2 voice coil, you should be able to power each voice coil with each channel of your stereo amp
How I Can Bridge This Power Amplifier??? broka Solid State 2 10th December 2006 10:43 PM
Bridge amplifier on 8 om matic Solid State 8 16th September 2006 09:44 PM
Bridge SE amplifier croccodillo Tubes / Valves 3 17th February 2006 01:58 AM
how to bridge an amplifier MV Car Audio 1 25th March 2004 05:11 PM
Modifications for HK Citation II Power Amplifier alaskanaudio Tubes / Valves 15 15th October 2002 03:21 PM
Page generated in 0.06451 seconds (77.87% PHP - 22.13% MySQL) with 10 queries
