| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I would like to build a speaker for listen to the radio (FM). I found this kit for a FM tuner with an integrated amp that is based on a TDA2003: FM Radio Receiver (1055) I was thinking that the amp is not powerful enough so I'd like to upgrade the chip with another one more powerful: can the TDA2003 be replaced with something else like a TDA2040 or TDA2050 using the same circuit supplied with the kit? Thanks in advance for every suggestion. Ralf |
#2 |
The short answer is no. Although the 2040 & 2050 are in similar packages to the 2003 the pinout is different and the circuit around them is not the same.
Sorry Tony. |
#3 |
Thanks.
In the case of building only the amp, would the following circuit be OK? (look at figure 3 on page 6): TDA2050 datasheet Or there is a better circuit? TIA, Ralf |
#4 |
Yes, that circuit would work - but it won't give you more power, and requires more components and different values than the original board. There is a topic in here about 12 volt amplifiers, but anything more powerful would require another PCB and maybe a more robust power supply. Simplest solutions are bridge amplifier, like TDA7240.
There are many designs and ideas to be found by searching around. Have fun.
Steve |
#5 |
sregor,
if I will build the amp around the TDA7240, would this be good for powering it? 40W 12V DC 3.2A Regulated Switching Power Supply Thanks, Ralf |
#6 | |
But might as well be.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#7 | |
One more comment/ observation. The TDA2003 can work on higher voltage supplies. It would require a larger resistor to drop the voltage on the tuner chip, and making sure the caps in the circuit are of high enough value. pacificblue: Although the pins are labeled simlarly, the 2003 has built in biasing for single supply use, which must be externally added to other amp modules. (Also, the - input is a low impedance input, which makes the 2003 difficult to use in circuits designed for other amps.)
Steve |
| Low Powered Inverting Amp (TDA2003) | rossco_50 | Chip Amps | 10 | 29th July 2009 07:31 PM |
| Help with TDA2003 amp | Tahmid | Solid State | 7 | 14th July 2008 05:21 PM |
| 41Hz AMP2 upgrade... What parts to upgrade? | MotoMan_Yz400 | Class D | 2 | 6th March 2008 05:28 AM |
| Help with Cana-Kit using TDA2003 | noob for now | Chip Amps | 1 | 8th December 2005 09:08 AM |
| TDA2003 hum ¿PSSR problem? | sync40 | Chip Amps | 3 | 2nd November 2005 06:40 AM |
| Page generated in 0.08845 seconds (78.25% PHP - 21.75% MySQL) with 10 queries |
