| Chip Amps Amplifiers based on integrated circuits |
I have dual secondaries trafo that I would like to use for my LM3875 gainclone. I am just not sure how to wire the four main leads for 110V. Here is the picture and specs are:
in: 110/220V 60/50Hz wires: orange red brown black out: 2 x 21.5V 2.7A wires: blue black wires: red white Is there a simple way to measure what's what or maybe somebody have the same trafo in their project? Thanks. |
#2 |
In theory you need to parallel the two primaries & nothing else. The pic helped but i'm still not sure as there is no mention of primary phase.
From what i can gather you need to connect the Orange & Brown together & then the Red & Black together & you should have a 110V primary. One end IE Orange/Brown will become Live & the other end (Red/Black) will become Neutral. Well that's if they explained things without confusing people too much. I'd check it out by feeding the thing with a function generator output at 50/60Hz before sticking mains into it first though, just to make sure the primaries are in phase If it's wrong you'll get no output voltage on the secondaries.
"Never let your morals prevent you from doing what is right!" Salvor Hardin |
#3 |
This is precisely the query I had many years ago, before I discovered that the bulb tester existed.
Use the bulb tester between the mains and your transformer. Identify the two pairs, a pair has near zero resistance between the wire ends. Couple one pair of primary wires to the plug top. Power up. The bulb might flash dimly or not at all. Check the secondary AC voltage. Switch off. Was the secondary voltage as expected? Now add the second primary in parallel to the first at the plug top. Power up. The bulb will light up or will flash dimly and go out. If it lights up, the primaries are out of phase. Swap the two wires of the second primary that you just added. If the bulb goes out, check the secondary voltage. You cannot blow the mains fuse doing this, you cannot damage the transformer doing this. Try doing the wrong phasing of the Primary without a bulb tester is risking a serious fault and damage to equipment and yourself.
regards Andrew T. |
#4 |
Thanks. I have test bulb setup and ready (that's from my first gainclone project).
#5 |
I have the XFM-D0012 toroid too from Apex Jr and verified that the primary
windings are Orange-Red and Brown-Black. Taking a guess at the phases, the likely connection seems to be - 110V Line - Orange+Brown 110V Neutral - Red+Black The bulb tester is your friend here. Note: I haven't hooked up this toroid, and I am not on 110V mains. Last edited by quadtech; 30th March 2010 at 05:34 AM. |
| 22 AWG silver plated solid copper wire for speaker wire? | G | Full Range | 21 | 15th February 2009 09:32 PM |
| Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? | rhythmdiy | Chip Amps | 9 | 23rd October 2007 12:30 AM |
| magnet wire (not sure of the term) used as chassis wire? | jarthel | Parts | 8 | 27th September 2006 09:50 PM |
| How to wire a Ixos Gamma 7 bi-wire cable | mangalchacha | Multi-Way | 1 | 13th April 2005 02:58 PM |
| Removing isolation of trafo wire | Thoru | Parts | 9 | 24th May 2004 08:40 PM |
| Page generated in 0.08733 seconds (77.40% PHP - 22.60% MySQL) with 10 queries |
