Old 29th March 2010, 09:21 AM   #1
Default TDA 2822 Dual Supply?
I just bought two audio amp kits that use the telefunken clone of the TDA 2822 chip. Now its a single supply kit, that i want to use for powering a set of headphones.
Does anyone know if i can convert it to dual rail? I plan on using a regulated -+ 5 volt supply to power them, as i dont need much power for headphones.
I really dont want to have to use a coupling cap for input and output, and the only way to do that is use dual rail.
Thanks.
Old 29th March 2010, 06:00 PM   #2
The TDA2822 will work from a split supply. Although a single supply implementation with AC coupled in- and outputs will probably lead to the same result.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Symmetric supply or dual supply? JWFokker Parts 32 11th August 2011 08:29 PM
Dual supply for LM1875 split supply dovganj Power Supplies 30 6th November 2009 03:19 AM
tda 2050 power supply/pcb scaesic Pass Labs 14 6th July 2007 03:38 PM
strange chip UTC FM93 2822 NIC1138 Chip Amps 3 15th May 2007 02:59 AM
TDA3875 and TDA3886 and TDA 4780 Single Supply Biasing abid_rehan Chip Amps 3 28th February 2004 04:21 PM
Page generated in 0.06232 seconds (71.05% PHP - 28.95% MySQL) with 10 queries
