Old 29th March 2010, 05:19 AM   #1
hd220 is offline hd220  Canada
hd220's Avatar
Default Speaker Protection board from Ebay
Has anyone any experience with these boards?
I picked up a couple of these reasonably cheap from ebay seller zoe_tsang. He sent the following connection diagram which I do not really understand. He says he doesn't have a schematic (typical of Chinese sellers) but ignored a request in the same email to clarify the connections.
(I know, buyer beware of buying from China on Ebay but they were cheap so not much is lost other than experimenting time.)
The second picture is of the connection diagram the seller sent after I bought it last year.
Old 29th March 2010, 06:39 AM   #2
Mooly's Avatar
Have you looked at the data sheet for typical application ?
http://www.datasheetcatalog.org/data...ec/UPC1237.pdf
It needs a supply ! which will feed into the diode as marked. The diode means you can feed either AC or DC into the PCB.
Identifiy the ground connection.
Identifiy the inputs from the amplifier.
Identifiy the relay connections.
Easy
A simulation free zone. Design it, build it, test it.
Old 29th March 2010, 09:09 AM   #3
kavermei's Avatar
Send a message via MSN to kavermei
入 means 'in', 出 means 'out'.
Never send a human to do a machine's job. --Agent Smith
Old 29th March 2010, 02:30 PM   #4
hd220's Avatar
Thanks Mooly and kavermei;
(Apologies for the camera phone pictures below - not always clear with closeups).
The boards I have are labeled in English. The relay speaker connection side is clear and connections per the diagram I drew.
The +32V VCC+ (as labeled) connection is clear as is the GND, assuming one wanted to use DC to power the board.
There is an "AC 28" hole which connects to the transformer. What about the other side of the transformer? Where does it connect to? if it is the "GND" point, it doesn't work, the relays are open.
I'm not normally this blind to this, I do have some electronics experience but either the board is faulty (which I am doubting) or I am missing something.
I do have the datasheet and at first glance it wasn't helpful.
Old 29th March 2010, 02:43 PM   #5
kavermei's Avatar
It's hard to tell for sure without a schematic. If you could trace out the circuit diagram from the PCB traces, I'm sure we could tell you in a second.
Old 29th March 2010, 02:59 PM   #6
hd220's Avatar
kavermei:
My point precisely which is why I asked for a schematic. Lots of these boards are being flogged by several sellers and I thought perhaps someone on diyAudio might have come across it.
I'll attempt to trace it. It is double sided with some of the traces underneath the relays which I'll pull out if need be. At that point I should be able to figure it out and post it here for the diyAudio community for reference.
Old 29th March 2010, 03:15 PM   #7
prairiemystic's Avatar
I would use the UPC1237 IC datasheet for a schematic, if you Google it
Old 29th March 2010, 03:24 PM   #8
it is likely that the AC in is a detect loss of AC and disconnect speakers.
The PCB is likely to be powered by the two adjacent pads using DC.
regards Andrew T.
Old 29th March 2010, 05:33 PM   #9
kavermei's Avatar
Yes, that is quite likely, the purpose being to avoid the 'thump' in the speakers at power-off.
Old 30th March 2010, 01:33 PM   #10
hd220's Avatar
OK, so I've traced the circuit. It is virtually identical to the datasheet's typical application schematic. Very minor changes. I've redrawn it to make more sense. The amp L and R channel outputs are sampled by the two 56K resistors connected to UPC1237's pin 2. Any DC there and the relays open I guess.
Also, I think Andrew T and kavermei are correct, the AC connection detects loss of AC. Question remains, what is the other side of the winding connected to? It may not be (and isn't in my case) the PSU circuit ground.
The board is powered by VCC+/GND, not that or AC IN as I originally thought.
So, the schematic is attached for diyAudio community's reference.
TA7317 protection board Original Burnedfingers Solid State 57 20th April 2010 09:55 PM
Speaker protection board hook-up. schumpe Parts 16 14th October 2007 01:08 PM
PCM1704 PCB Board from Ebay Salar Digital Source 1 18th August 2007 09:26 AM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
Page generated in 0.09672 seconds (82.83% PHP - 17.17% MySQL) with 11 queries
