LM3886 - DC offset problem
Old 28th March 2010, 05:05 PM   #11
luis.jimenez is offline luis.jimenez
Default PS schematic
http://fusion101radio.com
Old 28th March 2010, 07:46 PM   #12
More annoying than the hum, which is bad enough, is the motorboating, really, more like a lawn mower... I have the xfrmr CT on the same ground point as the rest of the ground signals. Is that a problem?
You can hear the motorboating coming from the rectifier. I wonder if it's the snubber caps, maybe got damaged when the other rectifier burned? I'll try to connect without the caps.
Also, no music out when I connect the CD player to the amp. I checked the attenuator and it and all connections worked fine.
Old 28th March 2010, 08:04 PM   #13
that schematic looks like it's from the National datasheet.
That's the stripped down version that is likely to misbehave when beginners and intermediates try to implement it.
You need the AC coupled version from the datasheet with all the optional parts fitted.
regards Andrew T.
Old 28th March 2010, 09:06 PM   #14
Default motoroating
Thanks Andrew, I may indeed change layouts. I notice that when I relocate the rectifier, the motorboating either lessens or totally subsides. Is this a clue? Could the rectifier be too close to the star ground? the output signal wires?
Thanks again,
Luis
Old 29th March 2010, 08:29 AM   #15
the motorboating may be an LF instability, but I have a feeling it is a protection circuit re-triggering due to detection of a fault.
regards Andrew T.
Old 29th March 2010, 12:47 PM   #16
Andrew,
That makes more sense than anything else, as I have checked connections and moved things and nothing gets rid of it - also may explain why no output. So, if it's a fault, what could cause it on both channels? V levels are within specs.
Thanks for taking time to answer,
Luis
Old 29th March 2010, 11:57 PM   #17
tomchr is online now tomchr  Canada
tomchr's Avatar
I wonder if a protection circuit gets cranky because the mute pin gets pulled low too fast. The data sheet calls for a 100 uF cap there. Also, what's the resistance of the mute resistor (Rm)? The current through Rm should be at least 0.5 mA. So calculate Rm from Rm = Vsupply/0.0005. Round down to the nearest standard value.
Your "amplifier board" circuit should work if Cm is fitted. You may have some offset on the output. The max input referred offset of the LM3886 is 10 mV. With a gain of 22k/680 = 32.4, the max voltage offset you should see on the output of your amp is 324 mV.
Note that all the grounds in your schematic should come together at one point - the star ground. The hum you are describing could be caused by a floating input ground.
~Tom
Old 30th March 2010, 12:02 AM   #18
tomchr's Avatar
What do you mean by "relocate the rectifier"? If you physically move it around without disconnecting any of the wires, then I bet it's a cold solder joint somewhere around the connections to the rectifier.
The rectifier does not connect to the star ground so its location with respect to the star ground should not matter.
~Tom
Old 30th March 2010, 12:22 AM   #19
Tom, thanks for all the pointers and advise. I will fit CM and will verify Rm value. I will also check all solder connections.
Luis
Old 10th April 2010, 12:04 AM   #20
Hello again,
I corrected the ckt and got one channel to work, pretty quiet too. But, the other channel is still exhibiting some of the same symptoms, and it gets extremely hot right off the bat - the other channel doesn't. I checked everything and can't figure out what's causing it to get so hot. Could the chip be shorted inside? It amplifies the music, but very noisy and with a cadence, not like the motorboating earlier but like the protection ckt is kicking in and out, in and out, every half a second.
Any help is appreciated.
Thanks,
Luis
LM3886 - DC offset problemHide this!Advertise here!
dc offset question (regarding LM3886 Chipamp kit) prospero21 Chip Amps 3 15th July 2008 11:19 AM
follow up: LM3886 RC filter + DC offset questions. blackboy Chip Amps 9 2nd May 2007 04:48 PM
LM3886 RC filter + DC offset questions. blackboy Chip Amps 2 27th April 2007 06:16 PM
DC offset problem whatsnew Chip Amps 17 2nd January 2007 08:26 PM
Same old story LM3886 and DC offset officeboy Chip Amps 11 24th June 2004 02:51 AM
Copyright ©1999-2017 diyAudio
