Bridgeclone - Rowland Concentraclone - Page 2 - diyAudio
Old 15th June 2003, 09:36 AM   #11
UrSv is offline UrSv  Sweden
UrSv's Avatar
Originally posted by mothman
A beautiful amp indeed and if I had the extra $7000 I'd buy one!
I'd settle for a dozen of the chip insulator pads though at this point.
Anybody know where a fit pad like those can be had?
http://www.schuro.de/
Silicon insulator pad in MultiWatt format. Standard issue but hard to come by.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 15th June 2003, 01:24 PM   #12
Send a message via AIM to ScottRHinson
If you run accross them I would love to know where, I've been looking for them too! That said, there is a universal part at Digi-key, part number BER190-ND that looks like it will work.
Scott
Old 15th June 2003, 03:49 PM   #13
mothman is offline mothman  United States
Thanks Scott and Guys,
For the thermal pad info.Yea it seems somebody stateside should have that 'multiwatt'size.I usually use the LM3886tf but have several of the 3886t I want to use.
R.C.D
Old 15th June 2003, 03:55 PM   #14
JOE DIRT®'s Avatar
mothman....I buy sil-pad by the sheet (12x12) and cut out what I want...its a tenth of the price that way....I know there are better insulaters out there...but I dont cut my corners on cooling and good thermal compound works for me
DIRT®
Old 16th June 2003, 10:23 AM   #15
Hey Joe,
Where do you buy your sheets?I'm not opposed to cutting my own at all.
R.C.D
Old 16th June 2003, 11:23 AM   #16
UrSv's Avatar
Most big guys have the sheets but since we are talking the states why does nobody look at for instance Digi-Key? Seems to be a fairly big supplier? They seem to have plenty but i don't know the company very well and not their catalogue either. Try any of the following most obvious potential candidates, all Multi-Watt as it seems, from their on-line catalogue:
BER190-ND
GAPPADHC100020MIL-ND
K4AC-124-ND
Some info :
http://dkc3.digikey.com/PDF/T032/0480.pdf
UrSv
Old 16th June 2003, 01:12 PM   #17
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
As regards clamping down the chip with something like those metal bars, I presume that the chips do have a breaking point and I wondered if the bars have to be carefully torqued down?
And I can just envisage a thread here about 'the best sounding torque setting'
Personally, I would prefer something springy with a bit of give to be on the safe side!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 16th June 2003, 04:13 PM   #18
Banned
I saw some internal pictures some time ago of the Linn 2250 power amp, on a spanish magazine.
It uses what seams to me as 3 x TDA7294 per channel .
The pictures were not very clear...
I wonder what topology do they use.
3 chips per channel...
3 parallel?
They claim 115w RMS / 8 ohms, 230w RMS / 4 ohms.
Old 16th June 2003, 04:40 PM   #19
Banned
Originally posted by miguel2
The signal goes directly from the jensens to the vol control and then to the output chips? No other gain/buffer ICs in between?
Miguel
The CS3310 is a buffer/gain stage too.
Check here:
http://www.cirrus.com/en/products/pro/detail/P2.html
It says:
"The CS3310 includes an array of well-matched resistors and a low noise active output stage that is capable of driving a 600 W load. A total adjustable range of 127 dB, in 0.5 dB steps, is achieved through 95.5 dB of attenuation and 31.5 dB of gain"
Old 18th June 2003, 05:58 AM   #20
The PCB screw is grounded to the chassis? Look closely.
Is this the correct way to ground
the "ground plane" on the pcb ?
Bridgeclone carlmart Chip Amps 138 1st April 2005 07:53 AM
Bridgeclone question B.VDBOS Chip Amps 9 2nd September 2003 07:56 AM
Copyright ©1999-2017 diyAudio
