Old 27th March 2010, 12:18 AM   #1
maurycy is offline maurycy  United States
Default Which trafo option for LM3875?
This would be for stereo LM3875:
Option 1: two PSU boards powered by two 21V-0-21V 80VA toroids (one per PSU).
Option 2: one PSU board powered by one 2x21.5V 2.7A
Which option is better? I am leaning toward option #2 as the space in the case is pretty tight. Option #1 would work but it would require major thinking when it comes to part placing and wiring.
Also, am I correct in my math that the two options are only 0.5A different (converting VA to A)?
Thanks.
Old 27th March 2010, 09:54 AM   #2
can you afford the cost of two transformers and two chassis?
regards Andrew T.
Old 27th March 2010, 12:01 PM   #3
I have the aluminum case all cleaned and I do not want to get more trafos. I want to stick to what I already have. Wife already thinks I am crazy collecting all the electronic parts :-)
Old 27th March 2010, 01:07 PM   #4
I think you are saying you have two 80VA transformers, two PSUs, two amplifiers, one chassis.
You are one chassis away from dual monoblock amplifiers.
I expect monoblock to perform better than option 1 and option .
regards Andrew T.
Old 27th March 2010, 02:57 PM   #5
What about just staying with the listed options? Which one would work better?
Is it good option? Prabot Everything Else 2 4th June 2008 10:46 AM
Electrocution not an option ... Bluto Analogue Source 13 28th March 2008 04:18 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
Lafayette Bypass Option D0Hbert Tubes / Valves 10 22nd February 2005 04:18 AM
Page generated in 0.09344 seconds (65.95% PHP - 34.05% MySQL) with 10 queries
