Old 26th March 2010, 10:16 AM   #1
Send a message via MSN to pyromaniac_
Default Groudning the chassis for the chipamp?
Hi, I've recently built a TDA2040 stereo amp, two chips and PSU in the same box. Because the chassis is alu, it's connected to the safety ground (don't sure about the english term btw). My question is then, should the zero V point of the PSU also be connected to the chassis as well?
The thing is that the amp works except one annoying little error. Then it's connected to my iBook I get some quite loud hum (sounds like the old familiar about 60 hz sound). The strange thing is that this doesn't happens then it's connected to my iMac instead. Because the imac is grounded (safety grounded) and the ibook isn't, I thought this could have something to do with the grounding of the amp, since I also get this hum then nothing is connected to the amp.
Old 26th March 2010, 10:58 AM   #2
If you are getting hum with nothing connected, something in your circuit isnt right. Try connecting the ground of your PSU to the case and see what happens.
Old 26th March 2010, 11:03 AM   #3
sangram is offline sangram  India
RCA input sockets should be insulated from chassis or you'll get hum from sources which are plugged into a common earth point...
Old 26th March 2010, 11:13 AM   #4
Thought so too, I'll try to connect the PSU ground to the case and see what happens. Worst case; I'll black out the whole apartment, but whatever...
They are.
Old 26th March 2010, 11:17 AM   #5
Do you also get the hum when the iBook is on battery power?
Old 26th March 2010, 11:33 AM   #6
Yes, there no different when it's on battery power or not.
Old 26th March 2010, 12:39 PM   #7
remmelt is offline remmelt  Netherlands
Are you using the grounded Apple plug or the duckhead? That might be the difference between the iBook and the iMac.
Old 26th March 2010, 12:47 PM   #8
Then it's a ground loop for sure. And it's inside the amp - if it quietens when you connect the iMac.
Are the two channels sharing any ground apart from the central star? The two channels share a single power supply?
Old 26th March 2010, 08:50 PM   #9
The duckhead (ungrounded) for the iBook, which probably makes the difference between the iBook and the iMac. I thought so too.
Ok, if it's from inside I should try to connect the chassis to the ground of the power supply right? Haven't tried this yet, hope I'll get the time to do it tomorrow.
Well, let me think.... to start with - they share the same power supply. But I can't think of anyway they could share the ground except the central ground star... it's like this;
signal ground ch 1 -> (single connector) -> output and psu ground ch 1 -> PSU* <- output and psu ground ch 2 <- (single connector) <- signal ground ch 2
Ok, quite hard to describe but I you'll get it anyway.
*And here's there I should connect the chassis?
Old 27th March 2010, 03:44 AM   #10
Can you try to route the grounds back individually to the central star, instead of to the individual grounds on the boards?
So you will have a single point at the PSU where four grounds will connect - the two PSU grounds and the two signal grounds. For some additional noise benefits you can use a small resistor (~2-4 ohms) between the signal grounds and the star.
My chipamp zymurgn Chip Amps 25 3rd December 2008 05:29 PM
Another first chipamp A Sanchez Chip Amps 18 4th June 2008 07:44 AM
What d'you put in the PSU chassis, and what in the circuit chassis? andyjevans Tubes / Valves 5 14th December 2007 11:41 PM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 04:28 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 05:37 PM
Page generated in 0.10969 seconds (82.34% PHP - 17.66% MySQL) with 11 queries
