| Chip Amps Amplifiers based on integrated circuits |
Suppose a Euro toroid is rated 200 VA, 230V primary, 2x35V secondaries.
If you used it on US power, e.g. 115V on the primary, what would the secondaries supply? |
#3 |
I had thought the potential current would increase but not double because of resistance losses and lowered voltages. The VA rating would by and large remain approximately the same but the transformer would lose some efficiency.
#4 |
I think the windings are sized for the current they were speced at at would overheat if you tried to draw twice the current/half voltage through them. There would be an efficiency loss due to the relatively high primary resistance. It will work at half voltage but will not have the regulation of a transformer designed for 120 volts.
Finding new ways for the extreme mis-application of high tech! |
#5 |
It would output half the voltage, but if you were to connect the twin secondaries in series, you could still pull 35 volts from it...
#6 |
halving the mains supply voltage results in half the output voltage and half the VA.
regards Andrew T. |
| Help reqd - 115V PTX on 230V | aardvarkash10 | Tubes / Valves | 20 | 6th November 2009 07:23 AM |
| Help Convert Bryston BP-20 PS from 230v to 115v | ainami | Solid State | 5 | 12th December 2008 06:01 AM |
| Question about autotransformer ( 230V to 115V ) | Rodeodave | Power Supplies | 5 | 4th June 2007 01:11 PM |
| 115v conversion fro 230V Cambridge Audio CD4 and Dacmagic 2i | taskerc | Digital Source | 4 | 7th February 2006 07:02 PM |
| Looking for 230V >1KVA variac and 230V-230V mains isolation transformer offers | Eva | Swap Meet | 1 | 28th July 2005 03:00 PM |
| Page generated in 0.07585 seconds (77.67% PHP - 22.33% MySQL) with 10 queries |
