| Chip Amps Amplifiers based on integrated circuits |
As per attached picture first-top amp may be act as high pass & bottom-2nd amp as low pass. 1st amp is 2nd order HP & 2nd amp is 1st order LP. While connecting speaker it may act as HP&LP mixer. 1st amp output 15watt & 2nd amp's output 30watt.
I did not build this. I want approval, how does it sound ? advantage & disadvantages. Anybody worked on this |
#2 |
Try drawing a proper schematic, with all the pins of the TDA2030 properly labeled, and you may get a response. The image you've uploaded doesn't show a schematic.
#3 |
Is this Okey.
#4 |
Try Looking in the TDA2040 Datasheet , it shows you how to do this properly and even has a PCB design ......
| tda2030 amp getting noise when connecting pocket tv | ruleworld | Chip Amps | 1 | 15th August 2007 04:05 PM |
| 200w Tda2030 Amp - Need Help ! | Mx | Chip Amps | 12 | 20th June 2007 02:39 PM |
| GIGA AMP TDA2030 single(or)bridge with tone control & mic | myanmar | Chip Amps | 5 | 6th February 2007 06:28 AM |
| TDA2030 for high power amp. | Dj BASS AMP | Solid State | 14 | 18th March 2003 10:06 PM |
| Page generated in 0.08122 seconds (70.92% PHP - 29.08% MySQL) with 11 queries |
