So just how "good" can a chip amp be ? - Page 11 - diyAudio
Old 28th June 2010, 05:31 AM   #101
Originally Posted by abraxalito View Post
I'm not suggesting the design isn't legitimate, just that the specs are overly optimistic. But that's fairly common in the audio world.
It certainly suggests it should be a reliable piece of equipment. But what does he know about achieving high quality sound from the design of medical power supplies I wonder?
He's been designing audio a long time, is an avid audio gear type, probably just like you. Give him a call if you really want to offer some comment.
This is interesting. If my amps had low performance in THD+N I'd not be trumpeting the fact. Or is there something of the hair shirt mentality coming in here - low performance in THD means its optimised for something other than linearity?
I'm sure its a typo
Where full power is 100W into 8R? I can't help but see the irony here - the reason it never gets hot at full power is because it thermally limits and effectively shuts down.
You're guessing here
More hype here - the min specified slew rate is 7V/uS for the chip, 10 is the typical figure. Are we to believe that he hand picks the chips for better than typical slew rate?
I don't know, do you?
A rather dismissive set of replies
I don't have a copy of IEC 60268-3 so maybe it allows short term output power to be put on the spec sheet. Anyone else know about this?
Old 28th June 2010, 08:56 AM   #102
Hi Phil,
Abrax has read the specification and rightly draws his conclusions, much of which he says are exaggerated.
You have read the specification but literally accept everything printed but with no thought about how the numbers have been massaged to look better than achievable.
I would be more inclined to put more faith in Abrax's interpretation.
Go back and read the spec again and the datasheet and compare Abrax's comments to what is printed in those sheets.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th June 2010, 10:53 AM   #103
madass is offline madass  Netherlands
How good is a chip amp compared to the cheapest stereo amps like the Pioneer A-209R (140 euro)? If both of them are not clipping.
Old 28th June 2010, 10:54 AM   #104
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Can't think why I'd need to call him to repeat what I've already put in the public domain here.
Yep, but its an educated guess based not only on the manufacturer's datasheet but my own experience with the part in question. Your basis for supporting the claims is what?
Nope, but another educated guess suggests not - its consistent with some of his other claims (and potential typo) that this >10V/uS is an erroneous claim.
On the contrary, your replies are dismissive as they don't engage with the content of my arguments. Have you looked at the datasheet yourself? Have you seen ST Micro's own claims for the TDA7294 and compared them with the claims for this amp?
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 28th June 2010, 01:02 PM   #105
sumaudioguy's Avatar
Only in reference to amplifier heating--- the lower the value of damping the less heat any amp seems to make. My amp has lots of feedback and very high damping. My first use of it on a sub with 100 square inches of heat sink was not even close to enough heat sink. It over heated right away. Further testing for the sub got me to the 300 square inches of heat sink value. This is for two of the chips (3886) running on 35 volts.
Yes in my circuit the slew rate of the composite amp was 1 volt per microsecond higher with the very same chip than the chip by itself. Nice surprise. Not the same number, the very same part.
What the other guy said----Standing on the shoulders of giants.
New avatar- no more little array
Old 28th June 2010, 03:16 PM   #106
I apologize for being dismissive.
I do think that it is better to keep the analysis less judgmental tonally.
However, it appears that those here who are more qualified than I, may in fact be correct in their assumptions.
I still accept that the designer may be correct unless I can prove otherwise.
As always, I very much appreciate this forum.
We all make mistakes and I hope to get better at not making them.
Old 28th June 2010, 03:21 PM   #107
[*]Low THD+N performance
I think you're misinterpreting that line. They are saying "Low THD+N" and added the marketing word performance.
Tyler
Old 28th June 2010, 04:36 PM   #108
abraxalito's Avatar
I agree with you, no judgement is better. But that's exactly the way I write - without judgement. Maybe because I write without judgement I'm more inclined to speak directly - that directness is what you interpret as being judgmental.
I hope to continue making mistakes myself as with no mistakes, there's no learning. So even though my style is to write directly, please do point out my errors - sure, we all make them.
Old 28th June 2010, 04:40 PM   #109
abraxalito's Avatar
Yep, I had thought of that way of looking at it and probably its what was in the writer's mind. But I decided to take the words at face value and have some fun with them It is quite common when an amp is marketed as 'audiophile' as this one is that distortion is either not specified or is quite high as a way of suggesting 'we concentrated on the sound in this design, if the distortion suffered in the process then tough, that's the price of great sound!'
Old 28th June 2010, 05:09 PM   #110
jez is offline jez  United Kingdom
Well I use a pair of LM3886 built to the standard NS circuit but good quality parts and very good earthing (it's DC coupled also) and I use this in preference to a Musical Fidelity A370 and Leak Stereo 20 valve amp. My 25WPC split rail supply JLH class A probably just beats it but some times I'm not so sure....
So yes they are pretty damn good by any standard.
"Mr. ED" Non-Inverting monobloc chip amp group buy. Russ White Group Buys 25 1st May 2010 08:14 PM
"toy" Chip amp Fast1one Swap Meet 0 5th October 2007 11:01 PM
The "Cheap, but good" rectifier & diode thread. Spasticteapot Parts 8 21st March 2006 02:44 AM
Is this "el cheapo" Velleman100wRMS kit good enough for a subwoofer amp? Spasticteapot Solid State 5 17th March 2006 09:09 AM
Hybrid "SE Tube Amp Sound Style" Chip Amp idea ThorstenL Chip Amps 24 7th February 2003 06:41 AM
Copyright 1999-2017 diyAudio
