So just how "good" can a chip amp be ?
Old 13th August 2010, 08:59 PM   #111
sumaudioguy is offline sumaudioguy  United States
sumaudioguy's Avatar
Of the three amps I find listenable around here my version of the 3886 comes in last by a nose. It is so close to number two I believe optimization of the 3886 may make it number two. The one I use was built with stock on hand and is not really optimum. On the other hand both #2 and #3 are some ways from the #1 amp. Also, #3 is still ahead of anything else tried in the marketplace... about 100 other "audiophile" amps and even some common stuff. As for common, the Insignia at Besty Bu is pretty darned good and very cheap. Please, this is just an opinion. Thanks.
What the other guy said----Standing on the shoulders of giants.
New avatar- no more little array
Old 5th May 2014, 12:59 AM   #112
jcx is online now jcx  United States
so what is the cheapest consumer A/V $/W with hackable analog power chip amps?
my quick look shows a Sony STRDH740 - "7x145 W, @6 Ohm" for $300 msrp - of course they are playing games with the rating - 240 W rating for the mains power??
whats inside? can we parallel 3 of the channels per side for a OK stereo amp? parallel+bridge for (likely weedy) monoblock?
maybe look for more realistic rated lower power chip amp based A/V amp
Pioneer VSX-822-K 5x80W at least claims a 450 max line power - $230 from Walmart
Old 5th May 2014, 05:32 PM   #113
The TDA7293V came in years after I had done testing. Clearly, that one is the best sounding by quite a bit simply using the data sheet design. The very cool things are higher voltage and designed with the intent to run multiple chips in parallel for greater current. Have not implemented my specific design using this chip but is on the to do someday list.
As for higher power, I greatly prefer more channels and a single amp connected to every speaker instead of trying to make a powerful amp pull a huge train with all those losses.
So just how "good" can a chip amp be ?Hide this!Advertise here!
"Mr. ED" Non-Inverting monobloc chip amp group buy. Russ White Group Buys 25 1st May 2010 09:14 PM
"toy" Chip amp Fast1one Swap Meet 0 6th October 2007 12:01 AM
The "Cheap, but good" rectifier & diode thread. Spasticteapot Parts 8 21st March 2006 03:44 AM
Is this "el cheapo" Velleman100wRMS kit good enough for a subwoofer amp? Spasticteapot Solid State 5 17th March 2006 10:09 AM
Hybrid "SE Tube Amp Sound Style" Chip Amp idea ThorstenL Chip Amps 24 7th February 2003 07:41 AM
