Old 16th March 2010, 11:34 PM   #1
Artie is offline Artie  United States
Default Virtual unity gain using voltage divider?
This is something I've been wondering for some time: I notice that some op-amps are not specified to be unity gain stable. Couldn't you just set the gain to maybe 5 or 10, and then run the output to a matching 5 or 10 resistive voltage divider for a "virtual" unity gain effect?
Seems too simple. I'm probably missing something.
Old 16th March 2010, 11:38 PM   #2
Steve Eddy's Avatar
Sure.
se
Old 16th March 2010, 11:47 PM   #3
No downside?
Old 16th March 2010, 11:49 PM   #4
Dr.EM is online now Dr.EM  United Kingdom
Dr.EM's Avatar
You could, but of course you'll increase the effective output impedence by doing this, making systems like active filters troublesome to design. In fact, most systems/stages requiring a unity gain are going to be severely restricted by having this increased output impedence, the fix for which is a unity gain buffer following it (making it totally irrelevant!)
I should ask specifically what it is you are trying to do, what this unity gain application is?
Old 16th March 2010, 11:50 PM   #5
Steve Eddy's Avatar
Well, you'll get a bit of additional noise due to the excess gain, and the voltage divider (just as with a regular attenuator) will result in the chip being driven from a bit higher source impedance which will increase distortion a bit.
Don't know that I'd lose much sleep over it though.
Why not use a unity gain stable chip like the OPA-549?
se
Old 16th March 2010, 11:52 PM   #6
Yes, but why bother?
It is not the amp design itself which has a specific stability, but how much internal compensation is applied.
I am not sure there are any op-amps available which do not have a version which is unity gain stable.
So use that one.
Old 16th March 2010, 11:56 PM   #7
Nothing specific. I started thinking about it partly because I have some older, high-power, non-unity gain stable opamps in my "junkbox".
Thanks guys for the responses. You brought up some points I hadn't considered.
Old 17th March 2010, 12:03 AM   #8
jcx is online now jcx  United States
"noise gain compensation"
Google
Old 17th March 2010, 12:20 AM   #9
Good reading. One of the first links listed took me to app note AN-20 from Apex Corp. One of the chips I was wondering about is an Apex PA02 high-power opamp. (5A output capability.)
Thanks.
Power Amplifier - Pre Amplifier Unity gain - Voltage gain - where as royal way ? tiefbassuebertr Solid State 9 9th June 2011 07:49 AM
Throwing away open loop gain with an opamp near or at unity gain okapi Pass Labs 3 25th December 2009 02:23 PM
voltage divider+Aikido anawat Tubes / Valves 0 17th October 2007 06:19 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 02:30 PM
Unity Gain Operation (or low gain) Tomo Chip Amps 12 22nd January 2004 02:47 AM
Page generated in 0.10272 seconds (81.23% PHP - 18.77% MySQL) with 10 queries
