Old 16th March 2010, 12:23 PM   #1
Arrow Please someone verify my TAS5615 amp PCB
Hi, please anybody verify my TAS5615 amplifier PCB for design rule and problems. I design this PCB with the help of TI application notes SLAU290. But the TI design is double layer PCB and my design is a single layer...
I am using a desktop CPU processor heat sink here. All the SMD components are in topside [soldering side] and all through through hole components are in others side[opposite to heat sink and all SMD components]..
And i want make sure about one-thing may i use the same PCB for TAS5630 amp[because these two's are pin compatible ]...
If anybody want this PCB i am happy to give you this in PROTEL ASCII format but i want to verify the design first...
Old 16th March 2010, 12:51 PM   #2
here is the PCB is pdf format.
Old 18th March 2010, 08:34 AM   #3
jash2008's Avatar
you can use TAS 5630 and TAS 5615 interchangeably without problems.
I think you are using SMD caps for A & D channel bootstraps whereas through hole caps for B & C channels. can you explain the reason.
Old 18th March 2010, 09:55 AM   #4
I always like to place through hole components[because of availability]. But there is a track is running between two terminals of the capacitor [This is the problem in single layer design]. Is there any problem in this. May i use smd and through hole cap together?... will they create any problem...
Old 20th March 2010, 07:34 AM   #5
jash2008's Avatar
You may use but preferably you should use SMD for class D application with keeping the tracks as short as possible.
But the bootstraps must be SMD and as close to pins as possible
need help to design a power supply for tas5615 udhay_cit Class D 5 19th March 2010 10:52 AM
Page generated in 0.07693 seconds (72.43% PHP - 27.57% MySQL) with 11 queries
