What's the problem - amp or speaker? - Page 2 - diyAudio
Old 14th June 2003, 04:24 PM   #11
pinkmouse's Avatar
Nuuk
I had a similar experience when I first started with GCs about a year ago.
I built a couple that always seemed to breaking up and distorting, with very low output. After checking, checking and checking again, I was totally bemused, so I finally connected up another driver, and lo, everything was fine. This confused me, as the old driver I then used in another system and it was fine. To cut a long story short, I eventually traced the problem to the length of speaker cable I was using as a test hook up, it had an intermittent internal short
Moral, check everything, not just the obvious!
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 14th June 2003, 04:33 PM   #12
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Thanks Al. I reckon the best solution would be to have a hi-fi mate and do each other's testing. It's like checking your own spelling mistakes when writing, often you just don't see them whereas somebody else comes along and points them out straight away!
I once bought an old Ford transit van with a seized engine. I bought another engine and swapped them over and while I was buying gaskets etc, I bought a set of new spark plugs.
But try as I might, I could not get that engine running. I stripped it down several times, checked everything in sight but after a couple of months, and a couple of experienced mechanics taking a look still it would not run.
Then one day, hearing my cursing, an elderly neighbour came over and suggested starting at the beginning and checking the spark plugs. I told him that they were all brand new, but he insisted on putting in the old ones and, you guessed it, the engine started first turn of the key!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 14th June 2003, 08:35 PM   #13
Nuuk's Avatar
I'm very glad to report that the little GC monoblocks are now singing again. For the record, the one with the new chip/coupling caps came into full flow after about 20 minutes. It was quite noticable!
And I'm pretty sure now that the chip that I took out is OK so I'm halfway to another GC
Speaker problem nandax Multi-Way 4 10th December 2008 08:33 AM
Car speaker problem Pintu Car Audio 2 14th November 2008 04:01 PM
esl 63 speaker problem brobarrie Planars & Exotics 1 10th July 2007 02:04 PM
Problem with JBL speaker system John Hope Car Audio 2 3rd June 2005 01:31 PM
speaker problem Xplorer Car Audio 1 9th June 2004 10:29 AM
Copyright 1999-2017 diyAudio
