Old 15th March 2010, 03:21 PM   #1
maurycy is offline maurycy  United States
Default Tight space in enclosure: vertically mounted trafo?
Are there any side effects of mounting trafo vertically in a tight enclosure? I am planning on adding second transformer to my gainclone but the enclosure is tall but narrow so I would have to mount them vertically attached to the side.
Thanks.
Old 15th March 2010, 04:17 PM   #2
pra3718 is offline pra3718  India
For myself it does not matter. I have mounted trafo this way. Yet, wait for expert's post.
Old 16th March 2010, 01:30 AM   #3
tomchr is offline tomchr  United States
tomchr's Avatar
I assume you are using a toroidal transformer. The leakage fields of your transformer will interact slightly differently with the amp circuitry, but I doubt you'll be able to detect much of a difference. In fact I remember seeing a National Semiconductor application note where they mounted the toroidal transformers vertically to save space. The measured performance of the amp was top notch. It might have been one of the app notes for the LM4702 but I don't remember exactly.
With an E-I core transformer, on the other hand, orientation does matter as its leakage fields are much stronger and more directional.
~Tom
Old 16th March 2010, 01:18 PM   #4
Yes, I have toroidal trafo. Thanks for replies. I will mount it vertically then.
What power do I need to move vertically 20kg with 4 speakers ? pianomambo Everything Else 17 7th February 2009 03:03 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 01:30 AM
Calculating For Cabinet Enclosure Space speedemon Multi-Way 24 23rd April 2007 04:47 PM
How does this arm pivot vertically? laserit Analogue Source 0 19th September 2004 12:48 PM
Page generated in 0.08009 seconds (70.23% PHP - 29.77% MySQL) with 10 queries
