Can some one suggest me an amp please
Old 13th March 2010, 05:15 PM   #1
Boscoe is offline Boscoe  United Kingdom
Default Can some one suggest me an amp please
I need a amp for the amplifier I'm making it needs to have 2 channels and i don't mind weather it's pre built or not. It needs to be about 30Wrms per channel and must run on 12Vdc. I don;t want anything from ebay i would like to buy it from a real shop and the price is as low as possible! Thanks
Old 13th March 2010, 05:25 PM   #2
Puffin is offline Puffin  United Kingdom
Probably a car amp would suit best.
Old 14th March 2010, 10:37 AM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
You need an amp with a power supply that has a built-in boost converter to convert the 12 V to the roughly +/-22 V needed to output 30 W into 8 ohm (assuming that's your load impedance). I second the recommendation of a car amp.
~Tom
Old 14th March 2010, 05:14 PM   #4
Thanks but now i think i'm going to try to make one from a kit. anyone got any ideas?
Old 14th March 2010, 07:16 PM   #5
wakibaki is offline wakibaki  United Kingdom
Banned
Lots of old car radios out there. I've bought them for 50p. 4 * 20W is common but 4 * 40W is not uncommon. Some have Aux In, but it's fairly straightforward to find one of the signal traces inside and break into it. You can feed into the tape circuit if there is one and select it by putting an empty casette in there.
w
Can some one suggest me an amp pleaseHide this!Advertise here!
anyone suggest a good quality replacement for NJM2115 [3028U] OP AMP at77 Parts 58 5th April 2017 04:27 AM
Audio amp. to IXFH26N50, please, suggest me an application/circuit to this component destroyer X Solid State 4 16th December 2009 02:03 PM
Suggest me a plate amp that... Telstar Subwoofers 6 23rd March 2009 12:34 PM
SE amp: Please suggest a better operating point zobsky Tubes / Valves 34 21st September 2008 01:00 AM
