| Chip Amps Amplifiers based on integrated circuits |
Hello there...
![]() Can we make TDA1554Q in bridge-parallel configuration? as it has 4 internal amp, 2 non-inv, and 2 inv. I have one of this Chip, and want to use it as sub power amp... regards.
_@ö sue |
#2 | |
#3 |
one thing I know from the datasheet is that when bridged it sum one of the non-inv and inv, and no parallel application in there.
do we can bridge-parallel or parallel-bridge this chip? use these chip as a sub is because of the application, its only in my room, no need a massive power I think. Infact some small 2.1 PC sound system only have about 5Wrms for the sub, with punchy bass..,
_@ö sue |
#4 |
Theoretically, you could parallel those 2 BTL amps using current sharing resistors on the outputs, but you won't squeeze any more power from the chip compared to BTL configuration unless your speaker is 2 ohms.
pra3718 already gave you good advice. |
#5 |
4R in BTL similar to 2R in each amp isn't?
I alreadx have TDA7294, in fullrange, adding a small sub to help the bass articulation is a good idea I think. I will try the BPA configuration latter then, since I'm not quite sure with the internal configuration of the chip... thank folks...
_@ö sue |
#6 | ||
Fullrange = tda1554q sub = tda7294 |
#7 | |
hellow there... the answer is yes. you can bidege-parallel the tda1554.. ok let say you put an input to pin 1 and 2 then at the output pin8 you connect it to pin 17 and 16.. BUT you make sure that you reduce the input voltage from pin 8 to pin 17 and 16 ... the input voltage in pin1 and 2 should be the same as your in put in pin 17 and 16 so you get the perfect phasing of the signal... |
| Parallel Bridge? | rgrayton | Chip Amps | 16 | 20th January 2009 04:50 PM |
| Bridge or Parallel? | Roushon | Chip Amps | 71 | 16th September 2006 07:47 PM |
| Parallel transformers and bridge | Raka | Power Supplies | 16 | 14th July 2005 08:15 AM |
| OPA549 x 8, bridge/parallel | soundNERD | Chip Amps | 2 | 14th March 2005 10:50 PM |
| parallel or bridge | rulezzz | Chip Amps | 1 | 8th January 2004 07:59 PM |
| Page generated in 0.08767 seconds (77.68% PHP - 22.32% MySQL) with 10 queries |
