| Chip Amps Amplifiers based on integrated circuits |
#11 |
Nice. Much better. You might be able to shave a bit off the width of the board by bringing the supply traces in at a 45 degree angle. You could then move the mounting holes down and in. Just a detail.
~Tom |
#12 | |
. . .. ... ..... ........ ............. ..................... .................................. My Best LM3886 PCB layout |
#13 |
Ok the voltage tracks are shifted to accommodate mounting screws. I hope after this i can make a prototype this weekend
#14 |
Just finished one prototype. Will run the amplifier tomorrow. The pads came out to be small and a little trouble with soldering. Will also increase the width to make component layout a little spacious and easy access to audio input and output terminals.Will update the PCB layout. More Build pics are here - DIY Audio Amplifier Blog: LM3886 first prototype
. . .. ... ..... ........ ............. ..................... .................................. My Best LM3886 PCB layout Last edited by kuldeepsingh; 18th March 2010 at 09:38 AM. |
#15 |
I would like to know if you have the layout as an eagle file.
I think I'll use this simple aproach instead of trying (too hard) to design my own p.s. sorry for bumping an old thread
#16 |
the + & - rails are too far apart.
They will act like an aerial and emit radiation into all the circuits nearby. Small loop area for circuiting currents is a must. Since the rails carry half wave rectified copies of the output AC then the power ground must also be included in the small loop area giving a triplet for the cable to the amp and for the traces on the PCB.
regards Andrew T. |
#17 | |
This is approaching paranoia. AC components on the power rails will be in the audio spectrum mostly, fairly low in amplitude, and sinusoidal. I don't think radiated emissions are much of a concern here. 'looks like a nice layout! Jim |
#18 |
And i'd like ask you is this amp working well ? ?
#19 |
Ya, its working fine, but i am not using it currently. i already have a LM4780 setup.
Would you like to make it yourself
. . .. ... ..... ........ ............. ..................... .................................. My Best LM3886 PCB layout Last edited by kuldeepsingh; 20th December 2010 at 03:51 PM. |
#20 | |
i don't have eagle layout as i use autocad. But you can have true size PCB layout in pdf format from my blog.
| Can Class D be built on a single side PCB??? | Leolabs | Class D | 9 | 12th January 2007 03:09 PM |
| Single side PCB for PA100 | zafira1981 | Chip Amps | 4 | 16th May 2006 12:02 AM |
| LM4780 Single side PCB | bill1961 | Chip Amps | 73 | 3rd March 2006 04:31 PM |
| Page generated in 0.10056 seconds (80.44% PHP - 19.56% MySQL) with 11 queries |
