| Chip Amps Amplifiers based on integrated circuits |
Can I install a DPDT to prevent turnon thump when i turn on my LM1875T amp - that way, i can turn off the speakers when i first turn on the amp and flip the switch to engage the speakers after the amp is on to prevent the thump noise. If so can someone please show me how to connect the thing. Sorry for the dump question as i am not much of a tech. Thanks.
#2 |
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
You could use an output relay and have it turn on a short time after the supplies come up. See attached as an example.
I don't know what rail voltages you're using. I assume something in the +/-20 ~ +/-30 V range. If that's the case, skip R1 and use a relay with 24 V coil. You might have to tweak the resistors a bit to get the delay you want. The idea is that the BC327 transistor turns on when the supply voltage exceeds 15.7 V (zener voltage + Vbe), thereby, turning on the relay. The relay will turn off quickly after you turn off the amp as it's on its own separate supply created with the 1N4004 diode and 1000 uF cap. If you get a thump at turn-off, you can make the relay drop out faster by connecting a diode across the 2.2 kOhm resistor (diode anode to the junction between the zener, 470 uF cap, and resistor; diode cathode to the (+) pin of the 1000 uF cap). The two 10000 uF caps I've drawn are your main supply caps. I don't know what capacitance you're using so I just put 10000 uF... ~Tom |
#4 | |
tomchr, i think the switch would be much easier for you to do. Thanks for the suggestion though. |
#5 |
I assume you are talking about a toggle switch. If the switch is mounted in a front panel so it toggles up/down, the center row of pins usually connect to the common point of the switch, i.e. pins 2, 5 in the schematic above. So wire the amp output to these pins. Left channel output to the left side of the switch, right to the right. Then if you want the speakers on when you flip the switch up, connect the speaker to the bottom pins of the toggle switch. Left to the left side, right to right. If you want the speakers on when you flip the switch down, you, of course, wire the speaker to the top pins on the switch. Simple, eh?
What you designate as the left and right side of the switch is arbitrary and really up to you. I generally make the "right" side the one that's on the right when I look at the amp from the front. That's my system. It just helps me so I don't get the channels crossed. If you're in doubt about the connections on that switch, I suggest getting one of these el-cheapo multimeters. Seriously! A low-end digital multimeter can be had for less than $10 and can save you a lot of trouble. ...and if $10 is too rich for your blood, a bulb from a flashlight and a couple of batteries can be rigged as a continuity tester. Easy. Figure out how the switch works, then wire it up. ~Tom Last edited by tomchr; 11th March 2010 at 08:37 PM. |
#6 | |
Then given you use a PIC with A2D you could then monitor for fault DC conditions and drop the relay out on a fault. I must admit I cracked doing it with just using i/o pins as comparators and didnt use a A2D PIC. I use this in my disco amps and have saved a fortune in speakers ! I got caught out with faulty leads shorting a couple of times blowing up the amp but the PIC saved the speakers. Leads on a disco tend to get pulled and tripped over so take a lot of abuse.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#7 |
Off topic and largely irrelevant, but I've ditched the PIC in favor of the Atmel AVR family of micro controllers. I got tired of the ad-hoc "architecture" of the PICs. I haven't looked back...
I considered using a micro controller for controlling the relays in my power amp, but decided to go with a dual D flip-flop and a "diode OR" gate instead. No software to debug... The D flip-flop turns a low-voltage push-button switch into a momentary switch driving the power relay. A circuit with an NPN and a zener diode monitors the supply voltage and starts an RC delay for the output relay after the supplies have reached about 2/3 of their nominal voltages. If the AC mains disappear, DC develops across the amp output, or the heat sinks reach 95 deg C, the power is cut and the output relay turns off. A fault condition also turns the ON indicator from blue to red (two LEDs with an acrylic light pipe). ~Tom |
#8 | |
| Moscode 600 hum/turn off thump | MattV | Tubes / Valves | 17 | 9th July 2011 09:13 AM |
| Amp emits deafening hum when I switch the kitchen light off! | rwtomkins | Solid State | 8 | 7th September 2008 03:59 PM |
| Transformer hum on leach amp, turn on / off thump | wigginjs | Solid State | 9 | 19th August 2008 12:06 PM |
| need help with carputer install, buzz/hum | Chris in NH | Car Audio | 6 | 27th September 2004 04:04 AM |
| How to install a cd phase switch | jimmyinhawaii | Digital Source | 3 | 18th February 2004 12:30 PM |
| Page generated in 0.10567 seconds (100.00% PHP - 0% MySQL) with 10 queries |
