diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   LM3886 Pin 7 to Power or Signal Ground? (http://www.diyaudio.com/forums/chip-amps/162675-lm3886-pin-7-power-signal-ground.html)
GregH2 6th March 2010 03:18 PM
Well I guess the title says it all.
Thanks,
Greg.
tomchr 7th March 2010 07:23 AM
Judging by the equivalent circuit in the data sheet (page 7), it looks like the ground connection is only used by the mute circuit. Thus, I'd return it to the power ground.
That said, the power ground and signal ground should meet at one point (star ground). You could also return the GND pin to this point via its own separate trace. That would eliminate any concern.
~Tom
AndrewT 7th March 2010 10:43 AM
I agree with Tom.
Pin 7 looks like it might pass modulated current under some operating conditions.
kuldeepsingh 7th March 2010 07:01 PM
By the way, In NS LM4780 reference PCB, the mute ground connects to signal ground and then to main ground via Rg. (page 22 of LM4780 NS datasheet)
GregH2 12th March 2010 12:15 PM
Great, thanks all.
Greg.
Resources saved on this page: MySQL 18.75%
